Warning message
Leo Laohoo Thu, 03/29/2012 - 14:29
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
need help to upgrade ios in cisco 4948 switch, I do not have admin right and network access
You have no network access to do an IOS upgrade?  Do you have PHYSCIAL access to the appliance?
You don't have admin rights?  Are you even ALLOWED to do an IOS upgrade?
nasiruddinm Thu, 03/29/2012 - 14:39
Yes, I am allow to do upgrade and I have physical access to the switch, I can use SecureCRT to transfer the IOS, but there is no xmodem option on 4948
Leo Laohoo Thu, 03/29/2012 - 14:51
  • Hall of Fame,
    2017 LAN, Wireless
Whao!  Whao!  Whao!
Let's step back for a moment here.
XModem?  Can you please elaborate what you mean by this?
I mean if you have permission and you are allowed to upgrade the IOS then WHY don't you have admin access?  What's going on?
nasiruddinm Thu, 03/29/2012 - 14:58
Usually I used SecurCRT to upgrade the other devices but not in 4948
Leo Laohoo Thu, 03/29/2012 - 15:04
  • Hall of Fame,
    2017 LAN, Wireless
Do you know the RW community string?
nasiruddinm Thu, 03/29/2012 - 15:09
No, but is there any way can I upgrade current IOS from cisco 4948 switch to another cisco 4948 switch!
Leo Laohoo Thu, 03/29/2012 - 15:54
  • Hall of Fame,
    2017 LAN, Wireless
You mean copy an IOS version from one 4948 to another 4948?  Sure.
Leo Laohoo Thu, 03/29/2012 - 16:12
  • Hall of Fame,
    2017 LAN, Wireless
Where the original IOS is from, enter the configuration command "tftp flash:filename.bin".
Where the IOS is going to, copy using the command "copy tftp:///filename.bin flash:filename.bin"
nasiruddinm Fri, 03/30/2012 - 09:05
Hi leolaohoo,
Would you please explain it step by step how to do this configuration!
Leo Laohoo Fri, 03/30/2012 - 15:17
  • Hall of Fame,
    2017 LAN, Wireless
Sorry, I'm getting lost here.  I've just posted how you can accomplish this.
nasiruddinm Fri, 03/30/2012 - 15:28
Hi leolaohoo,
I already figured out thanks for your support it help to find answer in your email, in the future if I have any problem I will contact you, once again Thank you so much!
nasiruddinm Mon, 04/02/2012 - 10:03
Hi leolaohoo,
After I download IOS image from 4948 to another 4948 it downloaded the image and showing image
boot system flash bootflash:cat4500-entservicesk9-mz.122-50.SG6.bin.
But when I looked up the dir bootflash: does not show any Image and after reload switch going back to again in ROMMON > prompt
Mandlenkosi Nkiwane Mon, 04/02/2012 - 12:39
  • Bronze, 100 points or more
Try:
rommon 1 > confreg 0x2102
rommon 2 > reset
If that does not work then I guess now you have to try and boot from the tftp server.
Leo Laohoo Mon, 04/02/2012 - 14:50
  • Hall of Fame,
    2017 LAN, Wireless
In your new 4948, can you please post the command "dir flash:"?
nasiruddinm Mon, 04/02/2012 - 15:03
Hi leolaohoo,
Switch#dir bootflash:
Directory of bootflash:/
1 -rwx 17338692 Mar 30 2012 14:56:48 +00:00 10.1.1.2
60817408 bytes total (43478588 bytes free)
Leo Laohoo Mon, 04/02/2012 - 15:16
  • Hall of Fame,
    2017 LAN, Wireless
I believe you've renamed your IOS to "10.1.1.2".
Leo Laohoo Mon, 04/02/2012 - 15:26
  • Hall of Fame,
    2017 LAN, Wireless
No that is the ip address for the switch!
No it is not.
The so-called "IP address for the switch" has a FILE SIZE OF "17338692".   You have renamed your IOS to "10.1.1.2".
nasiruddinm Mon, 04/02/2012 - 15:31
leolaohoo,
How I am going to change the file name would you show me step by step!
Leo Laohoo Mon, 04/02/2012 - 16:15
  • Hall of Fame,
    2017 LAN, Wireless
Command:  rename bootflash:10.1.1.2 bootflash:IOS_filename.bin
