Problem with CUBAC 8.6 Client in windows 7
Mar 29th, 2012
after migration to Windows 7 in CUBAC 8.6 does not display the corporate directory, error: Could not download the user preferences.
In the Parameters of the operator of the status shows the server as offline, if I connect it connects without problems, but again becomes disconnected.
Someone can help me. thanks
Overall Rating: 5 (1 ratings)
Gajanan Pande Fri, 03/30/2012 - 09:18
  • Cisco Employee,
Yesenia,
Is that 32-bit Win 7 or 64-bit ? If 64 bit then please note it's not yet supported on 64-bit Win 7. 32-bit is fine, details can be found here http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_bulletin_c25-563280_ps556_Products_Bulletin.html
GP.
Pls rate helpful posts by clicking on stars below the post !!
yesenia-m Fri, 03/30/2012 - 11:12
That's right, the Windows 7 32-bit is the one that I'm working, I reinstalled all the steps indicated by Cisco in this guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/ar/CUBAC_WA_86x.pdf and reviewed in this guide the Attendant Console and Client Software (http://www.cisco.com/en / US/docs/voice_ip_comm/cucmac/arc/CiscoTSGv8_6_x.pdf) but I still get the error when the login does operaodora and status as the primary server is not active.
thanks
jamgale Mon, 04/02/2012 - 06:50
  • Cisco Employee,
Firstly Windows 64-bit is supported on the client, it runs in WoW64.
A few things to check:
- can you resolve the hostname of the server
- Is UAC disabled
- Make sure the user has full control over the Arc Solutions registry key
- Does it work if logging in with an Administrator account
yesenia-m Mon, 04/02/2012 - 09:15
Hello Jamie
There must be an order to perform the installation procedure and once installed or should I check what you mention?
I disabled the UAC
I have in my hosts file the ip and hostname of the server, ping arrived for both parameters
work with an administrator account
After installation of CUBAC, I checked the user permissions for Arc Solutions in the registry key.
But I still have the same problem, same error, I can not see my corporate directory.
The version I had before is the 8.5, I do some changes to my server for me to accept the version 8.6 for the client?
yesenia-m Wed, 04/11/2012 - 08:11
and solved my problem, I really do not know much about it, the solution was to install the client with the same version as my server (I have made ​​clear that there must be the same version on both server and client)
Thanks for all your comments.
regards
