Warning message
Can't ping internal client from Pix 515
Mar 29th, 2012
I just setup my home network with Pix 515 acting as my router/firewall but I can't seem to ping my internal PC from my ASA. I can access the internet and ping my Pix 515 inside interface from my pc but I can't ping my pc from my Pix 515. I can also renew/release IP's from my PC. I also did a packet tracer and it says that it was dropped due to an access list but I have one in place. Also my switch has the default config. Below is my config
Internet <----> Comcast modem <-----> Pix 515 <-------> Cisco switch <-----> PC
MYFIREWALL# sh run
: Saved
PIX Version 8.0(4)28
hostname MYFIREWALL
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0
speed 100
duplex full
nameif outside
security-level 0
ip address 173.x.x.114 255.255.255.248
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 100
ip address 10.10.10.1 255.255.255.0
ftp mode passive
clock timezone EST -5
access-list 101 extended permit icmp any host 192.168.1.5 echo
access-list 101 extended permit icmp any any echo-reply
access-list 101 extended permit icmp any any source-quench
access-list 101 extended permit icmp any any unreachable
access-list 101 extended permit icmp any any time-exceeded
access-list 101 extended permit ip any any
pager lines 24
logging enable
logging timestamp
logging buffer-size 20000
logging buffered debugging
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) interface 10.10.10.103 netmask 255.255.255.255
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 173.x.x.118 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 0.0.0.0 0.0.0.0 outside
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 68.87.68.162 68.87.74.162
dhcpd address 10.10.10.100-10.10.10.150 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
prompt hostname context
Cryptochecksum:61717969523c7b3fe51286c96c733c27
MYFIREWALL# packet-tracer input inside icmp 10.10.10.1 8 0 10.10.10.103 detail$
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.10.10.0      255.255.255.0   inside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in  id=0x435ca18, priority=500, domain=permit, deny=true
        hits=1, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=10.10.10.1, mask=255.255.255.255, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Plinio Brandao Fri, 03/30/2012 - 08:31
Hi Edwin,
Maybe a simple question, but you have any firewall enabled at your PC? Some times we can do a ping, but we can't receive a ping.
Another test, if you create an ACL at INSIDE interface, permiting ICMP, what's the result?
Plínio Monteiro
zhohuang Sun, 04/01/2012 - 07:44
plinio is right , you need to close your windows firewall from control plan.
here's another test way, you can make a span on your switch :
monitor session 1 source interface fx/x -> connect to pc
monitor session 1 destination interface fx/x -> conn to another pc which running a wireshark or sniffer.
it will help you to decide the packet lost in which segment.
ejeangilles Sun, 04/01/2012 - 18:55
Sorry for the delay. After research I found out the problem was the that no ip directed broadcast was enabled on my switch vlan. Once I enabled it started working and ping was being received on my Pix.
zhohuang Sun, 04/01/2012 - 18:57
Good job
Best regards.
Zhongyu Huang
Date: 2012-04-02 09:55
To: Zhongyu Huang
Subject: - Re: Can't ping internal client from Pix 515
Home
created by Edwin Jean-Gilles in Firewalling - View the full discussion
Reply to this message by going to Home
Start a new discussion in Firewalling at Home
