Warning message
Learning CUCM
Mar 29th, 2012
How do I learn cisco unified communications?  I want to build a working system.  I have (4) 2811 routers and (4) 3750s.
I can purchase cisco phones.  Most of the documentation refers to "clouds" and broad level architecture.  Can I install cucm on 2 servers - (1) pub and (1) sub?
Is there a physical layer drawing available for setting up a system with (7) phones, wireless, with all servers and features?
Please assist.  I want to learn cisco unified communications.
Jaime Valencia Thu, 03/29/2012 - 18:55
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, you can install CUCM on two servers assuming you have the SW and your servers are compatible.
The network diagram for a lab is pretty much what you want to build/test.
In mine I just have the servers and phones plugged into a 3560 and a 3524 which has a trunk between them.
Router on stick as I have UC apps on 10.x.x.x network and ip phones on 192.168.x.x
GWs also on 10 network and a few PRIs between them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
