Warning message
Reorder Dial Peers?
Answered Question
Mar 30th, 2012
  • Blue, 1500 points or more
I have configured a CME 8.6 router with 20+ dial peers. I would like these to appear in the config based upon the numeric value assigned to the dial peer.
It seems that they appear based upon the order of configuration.
Is there any way (short of manually editing the config file and then uploading it) to reorder them?
I do not think this is possible but would like confirmation of this.
Correct Answer by ronpatel about 5 years 4 months ago
It will come in order of configuratoin only.....you can remove the config and put the edit one again.
Ronak patel
Please rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
ronpatel Fri, 03/30/2012 - 04:31
Ronak patel
James Hawkins Fri, 03/30/2012 - 05:51
Thanks Ronak,
I did not think this was possible but it is good to have that confirmed.
Aaron Harrison Fri, 03/30/2012 - 06:21
  • Community Spotlight Award,
    Member's Choice, May 2015
Hi James
I think a reboot re-orders them. Or at least it used to...
Aaron
James Hawkins Fri, 03/30/2012 - 06:39
Hi Aarron,
Thanks for the response.
I have just tried a reboot and the dial peers remain in the order entered
I am running IOS 15.2. I will try this on some older verions when I get a chance.
Related Content
