Software Compatibility Matrix between Unity Connection and CUCM
Answered Question
Mar 30th, 2012
I wan to upgrade my CUCM from  8.6.1.20000-1 to 8.6.2.20000-2.
My question is Could be able to just upgrade the CUCM and not the UNITY Connection?
Im planning to the Unity upgrade later.
any recommendation will be great
thanks
Correct Answer by Gajanan Pande about 5 years 4 weeks ago
CUCM 8.6.2 is compatible with CUEAC/CUBAC 8.6.2.11. Refer page 12 of following release notes
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUBDAC_Rel_Note8_6_2_11.pdf
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmac/arc/CUEAC_Rel_Note8_6_2_11.pdf
GP.
Pls rate helpful posts !!
Correct Answer by Jaime Valencia about 5 years 4 weeks ago
Depends, if you're talking about a CUCMBE 5K the answer is no, you upgrade the whole system.
If they're standalone installs, then yes.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Yes, you can. I presume your CUC is also 8.6.
GP.
Pls rate helpful posts by clicking on the stars below the post !!
Overall Rating: 5 (3 ratings)
Correct Answer
Gajanan Pande Fri, 03/30/2012 - 09:54
  • Cisco Employee,
GP.
alberto.douglas... Fri, 03/30/2012 - 09:58
Could you provide the documentation that show the CUCM could be a higher version than the unity COnnection in my case
alberto.douglas... Fri, 03/30/2012 - 09:55
The reason im doing this is because  Im
Installing Call   Manager version 8.6.2.20000-2 (to fix the CDR Database issue) but it  breaks CUEAC   "System Version: 8.6.1.9" (Administration Version: 8.6.1.158)
what would be the version for the CUEAC and for the CUBAC client that works with the cucm
8.6.2.20000-2. that im looking to upgrade?
thanks once again!
Correct Answer
Jaime Valencia Fri, 03/30/2012 - 09:57
  • Cisco Employee,
  • Hall of Fame,
    2011
java
alberto.douglas... Fri, 03/30/2012 - 10:00
I got 1 CUCM and 1 Unity connection ( no clusters )
where can I see if the im running
CUCMBE 5K ?
Rob Huffman Fri, 03/30/2012 - 10:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alberto,
Supported Version Combinations for Cisco Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Cheers!
Rob
