ASR9k and DOCSIS timing
Mar 30th, 2012
Hey
Any one know if its possible to use the asr9k (asr9000v) as an DOCSIS timing server for an uBR10k docsis 3 setup, so you can drop the external timing server?
Martin
Vadim Zhovtanyuk Sat, 03/31/2012 - 00:28
  • Cisco Employee,
Hi Martin,
As far as I know, according to DOCSIS Timing Interface Specification (CM-SP-DTI-I05-081209) there is a strong recommendation to use DTI Root and Slave server and also if they need to be located in different buildings (for instance) it is strongly recommended to use GPS or at least SONET/SDH network for syncronization between DTI servers.
Cisco IOS XR Release 3.9 introduces support for SyncE-capable Ethernet on the Cisco ASR 9000 Series Router.
But I'm not sure DTI Timimng protocol is the same as Sync-E so even if we can suppport Sync-E on ASR9K
http://www.cisco.com/en/US/partner/docs/routers/asr9000/software/asr9k_r4.2/interfaces/configuration/guide/hc42ethi.html#wp1012317
and tranposrt clocking over Ethernet links there is a question if DTI clients will be able to understand Sync-E
You may also ask uBR10K experts to verify if uBR10K DTI port is compartible with Sync-E and if Sync-E will be sufficient to "feed" DTP clent port on uBR10K with the clocking.
/vadim
P.S. As far as I see in the specification even the L1 specs are a little bit different for DTI UTP connection and standard Ethernet connection so I realy doubt DTI port will be able to "understand"  Sync-E.
