Cisco 3550 to 3524
Mar 30th, 2012
I have these 2 switches Cisco 3550 to 3524 as a test lab and I have set the 3550 up as the core\routing.
I want to trunk and talk between them but I cant get them talking, I've followed this:
http://www.ciscopress.com/articles/article.asp?p=29803&seqNum=3
Switch configs are below, 3524:
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport trunk allowed vlan 1-100,1002-1005
switchport mode trunk
interface VLAN1
no ip directed-broadcast
no ip route-cache
interface VLAN5
ip address 10.1.5.10 255.255.255.0 <<<<<<<<<<<<< My Management VLAN
no ip route-cache
shutdown
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
Switch#
3550:
bmi-c3550-core#show running-config
Current configuration : 2675 bytes
version 12.1
no service pad
hostname bmi-c3550-core
ip subnet-zero
ip routing
spanning-tree mode pvst
no switchport
ip address 200.1.1.1 255.255.255.0
switchport access vlan 2
switchport mode dynamic desirable
switchport access vlan 3
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.1.2.254 255.255.255.0
interface Vlan3
ip address 10.1.3.254 255.255.255.0
interface Vlan4
ip address 10.1.4.254 255.255.255.0
interface Vlan5
ip address 10.1.5.254 255.255.255.0
interface Vlan6
ip address 10.1.6.254 255.255.255.0
interface Vlan7
ip address 10.1.7.254 255.255.255.0
interface Vlan8
ip address 10.1.8.254 255.255.255.0
interface Vlan9
ip address 10.1.9.254 255.255.255.0
interface Vlan10
ip address 10.1.10.254 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 200.1.1.2
ip http server
line con 0
line vty 5 15
end
What am I missing?
Kyle McKay Fri, 03/30/2012 - 14:23
  • Bronze, 100 points or more
Which interfaces are you connecting together?
rdvorak Fri, 03/30/2012 - 14:45
On int vlan 5 do a "no shut" then you should be able to ping to the other switch interface on vlan5
harrisgirls Fri, 03/30/2012 - 15:01
Right i've applied the no shut to vlan 5 on the edge which I cannot ping the edge switch still:
nterface VLAN5
no ip route-cache
shutdown
I can now ping all vlans!
any idea still on the switch ip?
Also if I try and ping any default gateway from the core I get this:
Switch#ping 10.1.2.254
Sending 5, 100-byte ICMP Echos to 10.1.2.254, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Switch#
jonathansylvain Fri, 03/30/2012 - 15:12
Hi HGAED,
You don't seem to have a default gateway applied to the 3524, so it gets packets from your PC in the 10.1.2.0/24 network but doesn't know where to send it back.
Give that switch a default gateway of 10.1.5.254 and the 3524 will know where to send the icmp reply.
ip default-gateway 10.1.5.254
Jonathan S
harrisgirls Fri, 03/30/2012 - 15:18
Thanks Jonathan,
I've now applied that command, the output:
Switch#
Switch#ping 10.1.5.254
Sending 5, 100-byte ICMP Echos to 10.1.5.254, timeout is 2 seconds:
Switch#
jonathansylvain Fri, 03/30/2012 - 15:26
Ok at this point let's make sure it's not a L1 or L2 problem.
Do a show int gi0/2 on both switch to make sure they are both in an up/up state.
Jonathan S
harrisgirls Fri, 03/30/2012 - 15:28
3524:
Switch#show int gi0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is Gigabit Ethernet, address is 0008.a391.d2da (bia 0008.a391.d2da)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Auto-duplex (Full), 1000Mb/s, media type is CX_GIGASTACK
  output flow-control is off, input flow-control is off
  GigaStack module(0.2) in GBIC slot. link1 is down, link2 is up
  Last input 00:00:11, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
  5 minute output rate 3000 bits/sec, 4 packets/sec
     180 packets input, 18037 bytes, 0 no buffer
     Received 57 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 52 multicast, 0 pause input
     3558 packets output, 275150 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
3550:
bmi-c3550-core#show int gi0/2
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 000f.34b3.949a (bia 000f.34b3.949a)
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is CX Gigastack
  GigaStack module(0.2) in GBIC slot. link1 is up, link2 is down
  Last input 00:00:00, output 00:00:04, output hang never
  Output queue: 0/40 (size/max)
  5 minute input rate 4000 bits/sec, 7 packets/sec
     46120 packets input, 3455979 bytes, 0 no buffer
     Received 44939 broadcasts (0 multicast)
     0 watchdog, 43134 multicast, 0 pause input
     2750 packets output, 308592 bytes, 0 underruns
bmi-c3550-core#
From my laptop with static IP 10.1.2.5 I can ping all vlan gateways, from core I can ping laptop fine.
From core I cannot ping 10.1.5.10 which is the VLAN5 and IP of edge switch
Thanks for helping, I'm more a ProCurve man!...
enrique020 Fri, 03/30/2012 - 15:52
Issue "show interface trunk" on both switches, do you see your vlans on the trunk?
harrisgirls Fri, 03/30/2012 - 15:56
from 3550:
bmi-c3550-core#show interface trunk
Port        Mode         Encapsulation  Status        Native vlan
Gi0/2       on           802.1q         trunking      1
Port      Vlans allowed on trunk
Gi0/2       1-100
Port        Vlans allowed and active in management domain
Gi0/2       1-8,10
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/2       1-8,10
bmi-c3550-core#
bmi-c3550-core#
from 3524:
When I plum the command into the 3524 I get this:
Switch#show interface trunk
% Invalid input detected at '^' marker.
Switch#
enrique020 Fri, 03/30/2012 - 16:09
OK, try this instead on the 3524  show int gi0/2 switchport
harrisgirls Fri, 03/30/2012 - 16:11
Done from 3524
Switch#show int gi0/2 switchport
Switchport: Enabled
Administrative mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: 1-100,1002-1005
Trunking VLANs Active: 1-8,10
Pruning VLANs Enabled: 2-1001
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Switch#
Interesting from 3524, I cannot ping any gateways or laptop, but the laptop is connected to the 3524 and can ping gateways
enrique020 Fri, 03/30/2012 - 16:20
Try shutting down vlan 1 on the 3524, make sure vlan 5 is enabled and ping again
harrisgirls Fri, 03/30/2012 - 16:25
Getting somewhere now, I did have this:
interface VLAN5
no ip route-cache
shutdown
ran the no shutdown command on int vlan 5 and its come alive now!
Looks like I can ping everything between switches.
Looking at both switch configs in the top post is there anything else I need todo or any recommended commands?
enrique020 Fri, 03/30/2012 - 16:58
For the 3524,  I would say to assign the user ports to a vlan of your choice using the "switchport access vlan " and still shutdown the interface vlan1.
harrisgirls Sat, 03/31/2012 - 00:07
Thanks!
I thought it was harder setting up cisco switches..........
