1841 serial interface problem
Mar 30th, 2012
  In one of my client location cisco 1841 router and the link is down.
while i troubleshooting the serial interface they show like this.
so i check with the service provider they told line is ok.
  how to i locate the problem.
how to troubleshoot??/where is the problem our end or service provider end???
Serial0/1/0 is up, line protocol is down
  Hardware is GT96K Serial
  Internet address is 192.168.109.53/30
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP ACKsent, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 02:47:29
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
  5 minute output rate 0 bits/sec, 1 packets/sec
     299 packets input, 4186 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 3 giants, 0 throttles
     424 input errors, 424 CRC, 213 frame, 4 overrun, 0 ignored, 212 abort
     874 packets output, 12236 bytes, 0 underruns
     0 output errors, 0 collisions, 53 interface resets
     0 unknown protocol drops
     13 carrier transitions
    DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Average Rating: 4 (1 ratings)
Vasileios Bouloukos Sat, 03/31/2012 - 00:02
It seems that you have errors and CRC to your interface
Be sure that the link is ok.
you should have a layer 2 problem.
Check the mtu and full duplex is the same to both interface ends.
Also check any L2 encapsulation config. PPP config should be the correct and similar to both ends
Hope that helps
Vasilis
kumarpmt83 Sat, 03/31/2012 - 00:52
I clear the error and CRC using the command clear counter.
Config:
RDC-GODOWN#sh running-config
Building configuration...
Current configuration : 2260 bytes
version 12.4
hostname RDC-GODOWN
boot-start-marker
boot-end-marker
logging buffered 51200 notifications
enable secret 5 $1$DGSg$2d/PkBqOj7iypcHH6S8v80
enable password cisco
no aaa new-model
ip cef
isdn switch-type basic-net3
username cisco privilege 15 secret 5 $1$qB55$CoVxYzC/y/oB3SCOv0qw90
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.20.245.100 255.255.255.0
duplex auto
speed auto
keepalive 1000
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface BRI0/0/0
ip address negotiated
encapsulation ppp
dialer idle-timeout 180
dialer string 04428299970
dialer load-threshold 200 either
dialer watch-disable 15
dialer watch-group 10
dialer-group 1
isdn point-to-point-setup
ppp authentication chap
ppp multilink
interface Serial0/1/0
bandwidth 128
ip address 192.168.109.53 255.255.255.252
ip accounting output-packets
encapsulation ppp
router eigrp 100
passive-interface default
no passive-interface BRI0/0/0
network 10.0.0.0
no auto-summary
router bgp 65001
no synchronization
bgp log-neighbor-changes
network 10.10.245.0 mask 255.255.255.0
neighbor 192.168.109.54 remote-as 9829
no auto-summary
ip forward-protocol nd
no ip http server
snmp-server community startrac RW 55
snmp-server ifindex persist
snmp-server location ***DELHI-RO***
snmp-server contact ***Datacraft GSC , Bangalore***
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps envmon
snmp-server enable traps config
snmp-server enable traps cpu threshold
snmp-server host 152.102.153.235 startrac
Can u check any problem in my config.
How to check mtu value??
Any problem in modem or cable???
johnlloyd_13 Sat, 03/31/2012 - 02:17
hi,
ask the SP to give you a loopback from the nearest exchange towards the 1841. you must check from inside LAN and should see the serial link to be up/up (looped). if it's still up/down, push the SP to dispatch an onsite technician to check the cabling or the NTU.
kumarpmt83 Sat, 03/31/2012 - 03:14
I am not getting loop from my nearest exchange.
Any problem in modem or sp cable pair??
johnlloyd_13 Sat, 03/31/2012 - 03:26
yes and it's highly probable. ask the SP to send a tech in order to rectify your issue.
Vasileios Bouloukos Sat, 03/31/2012 - 04:56
I do not see any problem to your config.
Your mtu value can be checked with the show interface command.
To the provided output is 1500bytes
  Encapsulation PPP
It should be the same to the other endpoint.
The ppp negotiation is stuck to the LCP phase
(from your output)
If you type debug ppp negotiation you will see that L2 fails (ppp to be established) and this is the reason that the interface is up/down
Vasilis
kumarpmt83 Sun, 04/01/2012 - 22:17
I given the command debug ppp negotiation in the router
it shows like
PPP protocol negotiation debugging is on.
No error has came.
After that what i am to check?
Vasileios Bouloukos Mon, 04/02/2012 - 00:02
PPP can not be established otherwise you should see this subent as connected to the show ip route output.
Can you see this subnet to the routing table?
It seems that should be an error in the physical layer. I would suggest to procced with the actions mentioned by johnlloyd13
Login or Register to take actions
Posted March 30, 2012 at 11:35 PM
Stats:
Replies:9 Avg. Rating:4
Views:1192 Votes:0
Shares:0
Tags: No tags.
Categories: Routers
Discussions Leaderboard
