SFP-10G-LR and conditioning patch cord
Mar 31st, 2012
I would like to know if it's possible to use SFP-10G-LR with a conditioning patch cord ?
In fact wa have to deploy 10 Gb, but we dont have any information on the FO, so we have to figure the worst case: old SMF.
It seems not, but I would like to know if someone have already test...
It's for Nexus 5596, so we can't use LRM...
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/product_bulletin_c25-530836.pdf
Thanks a lot
Tom Randstrom Sat, 03/31/2012 - 07:34
  • Gold, 750 points or more
A mode conditioning patch cord (MCP) is used when you have multimode fiber in your network.  It allows certain laser-based transceivers to be connected to the multimode fibers.  Review the mode conditioning document I linked to above for more information on which transceivers it is designed to work with.
If you have SMF, you won't need a MCP.
GERALD LECAILLIER Mon, 04/02/2012 - 02:45
I made a mistake in my question, the old FO is not a SMF but a MMF...
So regarding your document, I'm not sure that I can plug mode conditioning patch cord between a SFP-10G-LR and MMF.
Thanks to you,
Paolo Bevilacqua Mon, 04/02/2012 - 14:31
  • Hall of Fame,
    Founding Member
You can, but if the circuit is too long, it won't work.
Tom Randstrom Mon, 04/02/2012 - 19:47
Your other option, although hardly a great solution, is to use a media converter at each end of your MMF backbone link.  Might be less expensive than installing new fiber.
The output from your Nexus equipment would be 10GBase-SX into the media convertor's 10GBase-SX interface which gets converted to 10GBase-LRM connected to your MMF backbone.  Same at the far end.
The following company supports 10GBASE-LRM transceiver modules on their media converters.   Other company's probably have similar equipment.
http://www.mrv.com
