CUCM GUI IS NOT WORKING
Mar 31st, 2012
CUCM GUI Showing an error.
I just bought a new cucm server from cisco . It has an cucm 8.0.3 iso image in its hardisk. I just installed it from there. And i did not put and licesence installation in it. And i started configuring it. After sometime it show an error.I am from India. I am going to install in some hotel in Noida in Delhi NCR. What should i do.
abarkalg Sat, 03/31/2012 - 02:22
Hi Pankaj,
                   Since you said that its a new server ....can you restart the server.  i see from our database that sometimes this solves the issue of this kind.
Abdul
Please rate helpful posts!!!
CSCO11921629 Sat, 03/31/2012 - 03:40
Hi Abdul,
               Thanks for replying. Yes actually i restarted it and just after that it showed me the same message but after sometime it got start working automatically. I want to ask something that is it really neccassary to install licesnce dvd and if then please tell me how to do that. Thanks
abarkalg Sat, 03/31/2012 - 04:25
Hi Pankaj,
                Please follow the link below.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_0_2/ccmfeat/fslicense.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_0_1/install/cmins801.html#wp494812
Hope this helps.
Abdul
ronpatel Sun, 04/01/2012 - 21:17
Hi Pankaj,
To access GUI you do not need license.
This is happening because, tomcat service and other GUI related services takes some time to start after reboot or initial boot. You will get GUI access will all the related services are started.  During that time you can see if you have ssh access.
Ronak patel
Please rate helpful posts by clicking stars below the answer.
CSCO11921629 Sun, 04/01/2012 - 23:20
hello friends.
                     I am just trying to add users by bulk administration. I have created the csv file , uplaoded that , created a user tempate and attached them in user insert mode with run immidiatlly but in job scedular status is showing peding whats wrong with that.
Login or Register to take actions
Posted March 31, 2012 at 2:07 AM
Stats:
Replies:5 Overall Rating:
Views:427 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
rob.huffman
21,530
Paolo Bevilacqua
15,141
Chris Deren
11,299
Ayodeji oladipo...
9,335
William Bell
4,940
Terry Cheema
325
Marcelo Almeida...
184
Aman Soi
101
bruno rangel
65
Aaron Harrison
61
