Do MCU 5300 series support flexible port configuration?
Answered Question
Mar 31st, 2012
Hi all,
I coudn't find an admin guide or something for MCU5300 series. I want to learn that if the ports are flexible or not. You know it supports up to 20HD or 40SD ports. Is it possible to make it support 10HD ports and 20 SD ports at the same time like Polycom RMXes? Or do I have to select one mode (HD or SD) and use only them in this mode?
Best regards,
Tufan
Correct Answer by Martin Koch about 5 years 1 month ago
From what I understood its the features of the MSE8510 in a standalone MCU.
On the MSE8510 its not possible, so I say:
No, its not possible to have a flexible port configuration.
So yes, its a fixed setting.
Here some older posting about the MSE8510:
https://supportforums.cisco.com/thread/2132414
Overall Rating: 4.8 (4 ratings)
Oleksandr Yurchenko Sat, 03/31/2012 - 06:53
  • Silver, 250 points or more
Hi Tufan
MCU5300 its new product. Now i found only datasheet.
In datasheet for MCU5300: Benefit - "Software selectable between HD or SD video ports"
But I think - this feature not same as plcm port feature and need to select one mode (HD or SD) and use only them in this mode.
Waiting admin guide or cisco man )
Br. Oleksandr
sagsheth Sat, 03/31/2012 - 10:02
  • Cisco Employee,
Hi Tufan,
Please see the snippet below
The Cisco TelePresence MCU 5300 Series:
  • Is standards-based and compatible with all major vendors’ endpoints
  • Is highly configurable and field upgradable
  • Offers a broad range of HD MCU entry points for customers
  • Is software-selectable between HD or SD video ports
  • Provides an upgradable unit with growth capacity using software port licenses
Point 4 states it has to be either HD or SD.
However I will confirm this and will be able to provide you concrete answer on Monday
-Sagar
Correct Answer
Martin Koch Sat, 03/31/2012 - 06:10
  • Red, 2250 points or more
crisalex Sun, 04/01/2012 - 00:11
  • Cisco Employee,
HI
It will work in either one mode or the other one , you can not mix HD with SD mode.
Cristian
huu hieu Thu, 09/04/2014 - 00:49
Hi Cristian,
I used MCU 5320. Can I mix HD with SD port ?  Because in datasheet of MCU-5320 described that: LIC-5300-4P is Mix license
If I have 1 Quantity of LIC-5300-4PL means 1 Full HD( 1080p) / 2 HD (720p) / 4 SD ( 576p)/ 8 nHD ( CIF).
Can I use for 3 endpoints:  1 HD and 2 SD ?
Thank you very much,
Hieu
Patrick Sparkman Thu, 09/04/2014 - 07:14
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Has been answered already here:  mcu5310-lic-5300-4pl.
In short, not possible to mix and match the media port types, can only have one type (ie: FullHD/HD/SD/nHD) active at any one time.
tufan.kabacioglu Sun, 04/01/2012 - 03:42
Thanks for all replies. I understand it is not flexible as I expected.We need that way in port usage as we compete with Polycom. I hope Cisco sees that need.
Best Regards,
Tufan
Martin Koch Sun, 04/01/2012 - 04:06
At least for the endpoints it does not matter as SD devices can still connect if its set to HD,
or HD systems to a SD configured MCU, but sure you only get SD quality.
At the end everybody needs to devide which features you really need.
We are happy with our MSE8000.
Tufan: please rate the answers with the Stars below each message and set the thread to answered if it is.
crisalex Sun, 04/01/2012 - 04:22
  • Cisco Employee,
Dear Tufan,
If this is impacting your / customer  bussiness I would really recommend to address this through your Key Account Manager as feature request
Kind regards
Cristian
r.tricard Thu, 05/10/2012 - 01:09
Is it the same issue inside a stack of MCU 5300 ?
For exemple is it possible to have a stack of two 5300, one configured with HD ports, the other one with SD ports... ?
Best Regards
Romain
Martin Koch Thu, 05/10/2012 - 07:33
Hi Romain,
you can see it on the datasheet, its not possible to mix, just see the cluster as one fixed unit which
has the same settings.
Sure you could run them indepndent and the Conductor will also become quite handy for such needs.
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11305/ps11317/ps12283/data_sheet_c78-692890.html
Model
Continuous Presence Video Participants (Symmetric)
Additional Voice Participants
MCU 5310
(with maximum numbers of port licenses)
10 x 720p30 HD ports
5 x 1080p30 or 720p60 Full HD ports
20 x w448p30 SD ports
24 x w360p30 nHD ports
None
None
MCU 5320
20 x 720p30 HD ports
10 x 1080p30 or 720p60 Full HD ports
40 x w448p30 SD ports
48 x w360p30 nHD ports
20
None
None
Stack of two MCU 5320s
(both with maximum numbers of port licenses)
40 x 720p30 HD ports
20 x 1080p30 or 720p60 Full HD ports
80 x w448p30 SD ports
96 x w360p30 nHD ports
40
20
None
None
Romain: Please rate answers with the stars below!
Martin
