OER is not otabatyvaet channel in the fall of one of the providers
Mar 31st, 2012
OER is not otabatyvaet channel in the fall of one of the providers. There are two routers that are connected to two different providers, you must configure the balance between 70 to 30. OER pondnimaetsya works, though not 70 to 30 (if anyone knows tell me where the tweak). Once off the main channel of the provider ceases to operate almost all, almost, because some sites continue to operate, the output of show oer master prefix becomes empty. What is wrong?
Config settings OER (between routers HSRP 10.205.248.13):
pfr master
95 logging
96 !
97 border 10.205.248.12 key-chain MMK-OER-CHAIN
98 interface GigabitEthernet0/0 internal
99 interface GigabitEthernet0/1 external
100 max-xmit-utilization percentage 70
101 interface GigabitEthernet0/0.1 internal
102 !
103 border 10.205.248.11 key-chain MMK-OER-CHAIN
104 interface GigabitEthernet0/0 internal
105 interface GigabitEthernet0/1 external
106 max-xmit-utilization percentage 70
107 interface GigabitEthernet0/0.1 internal
108 !
109 learn
110 throughput
111 delay
112 monitor-period 1
113 prefixes 1250 applications 1250
114 expire after time 6
115 aggregation-type prefix-length 29
116 backoff 180 360
117 mode route control
118 mode select-exit best
119 resolve utilization priority 1 variance 1
120 !
121 pfr border
123 logging
124 local GigabitEthernet0/0
125 master 10.205.248.13 key-chain MMK-OER-CHAIN
pfr border
94 logging
95 local GigabitEthernet0/0
96 master 10.205.248.13 key-chain MMK-OER-CHAIN
Sergey Prishchepa Sun, 04/08/2012 - 05:55
The experiments revealed that the incidence of internet channel works if connect to the router directly, ie OER did work out. But before the router is ASA, if any channel falls through it, while the OER, the Internet does not work. * If the OER is turned off, the fall of any channel switching provider is the default route through the ip sla and everything works. At ASA deny any appears. What could be wrong?
Related Content
