04-01-2012 01:08 AM - edited 03-19-2019 04:41 AM
Dears
I am reciving the mentioned error when trying to install the Unity Connection Ver 7 on IBM 7825-I$ Server
Please Advice how to create the reaid file manually .
Best Regards
Solved! Go to Solution.
04-01-2012 12:36 PM
First, make sure that your server model is supported with CUC 7, details can be found here
Once done verifying that your server is supported, Try following steps
# Boot the system and press F 8 to get into embedded RAID array utility
# From the text-menu screen, select the RAID array and delete the logical disk
# Once it is completed, exit the utility
# Re-attempt the installation.
GP.
Pls rate helpful posts by clicking on stars below the post !!
04-01-2012 12:36 PM
GP.
