Play leading zero in generated prompt`
Answered Question
Apr 1st, 2012
UCCX 7.0
Collecting ABA/Routing number from customer and reading back to them in a generated prompt:
generator type - number
constructor type - number, play full (false)
It is then read to the customer via an Explicit Confirmation.  However the playback is dropping the leading zero.  Need to have that zero read back to the customer.  Any help is appreciated.  Thanks.
Correct Answer by Aaron Harrison about 4 years 11 months ago
Hi Andrew
Instead of using a type of 'number', try the 'credit card' one.
Aaron
Overall Rating: 5 (1 ratings)
Gergely Szabo Sun, 04/01/2012 - 23:39
Andrew,
can you please make sure the ANI information really contains the leading zero (did you try to do some reactive script debugging)?
Also, if we are talking about non-system prompts, make sure the prompt (wave) file exists and its format is correct (can you see any exceptions perhaps in the MIVR*.log files)?
Could you attach a screenshot of your script? It would help us understand the way the prompt is being generated.
Thanks.
G.
Correct Answer
Aaron Harrison Mon, 04/02/2012 - 01:17
Hi Andrew
Aaron
Andrew Skelly Mon, 04/02/2012 - 13:15
I've been trying all day on different browsers, but I can neither rate the answer nor can I select it as the correct answer.  Tried IE, Firefox and Chrome, none of them work.
Andrew Skelly Tue, 04/03/2012 - 05:19
Looks like it's working again today (rating).  Thanks for your help, as always, Aaron!!
