The old native vlan question.....
Answered Question
Apr 1st, 2012
  • Silver, 250 points or more
Two switches, both connected to each other via e1/0.  Why am I getting a native vlan mismatch error when they are both access ports?
BTW, this is not live equipment, but a simulator.
DLS1#sh run int e1/0
Building configuration...
Current configuration : 106 bytes
interface Ethernet1/0
switchport
switchport access vlan 100
switchport mode access
duplex auto
end
DLS1#
*Apr  1 19:19:58.507: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on Ethernet1/0 (1), with ALS1 Ethernet1/0 (100).
DLS1#
ALS1#sh run int e1/0
switchport
duplex auto
end
ALS1#
*Apr  1 19:20:51.063: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on Ethernet1/0 (100), with DLS1 Ethernet1/0 (1).
ALS1#
Sh cdp fro ALS1:
ALS1#sh cdp nei det
Device ID: Router1
Entry address(es):
  IP address: 100.1.1.11
Platform: Linux Unix,  Capabilities: Router
Interface: Ethernet0/0,  Port ID (outgoing port): Ethernet0/0
Holdtime : 168 sec
Version :
Cisco IOS Software, Linux Software (I86BI_LINUX-ADVENTERPRISEK9-M), Experimental Version 12.4(20090407:185408) [yuiu-redbuild-V124_24_5_6_PIC1 177]
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 08-Apr-09 02:09 by yuiu
advertisement version: 2
Duplex: half
Management address(es):
Device ID: DLS1
Entry address(es):
Platform: Linu,  Capabilities: Router Switch
Interface: Ethernet1/0,  Port ID (outgoing port): Ethernet1/0
Holdtime : 170 sec
Version :
Cisco IOS Software, Linux Software (LINUXL2-UPK9-M), Experimental Version 12.2(20100802:165548) [mtimm-mtrosel2iol 102]
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 02-Aug-10 10:05 by mtim
VTP Management Domain: ''
Native VLAN: 1 (Mismatch)
ALS1#
ALS1#
ALS1#ping 100.1.1.1
% Unrecognized host or address, or protocol not running.
ALS1#
100.1.1.1 is a SVI on DLS1.
Correct Answer by jszapipes about 4 years 11 months ago
Would imagine that vlan 100 exists on only one of the switches. Also as mentioned above you must set your ports to trunk when connecting switches together utilizing a cross over cable.
Correct Answer by Imran Ul Haq about 4 years 11 months ago
Hi There,
First of all, configure both switchports as
Switchport mode trunk.
This should rectify your problem as both devices will have a default native vlan of vlan 1
Imran
Overall Rating: 5 (2 ratings)
Correct Answer
Imran Ul Haq Mon, 04/02/2012 - 14:20
Hi There,
Imran
Correct Answer
jszapipes Thu, 04/05/2012 - 15:29
jimmysands73_2 Fri, 04/06/2012 - 07:13
It was a lab I was doing, plus on a simulator, so who knows where the issue was.  Thanks for the replies.
