Speed Dial / Redial not displaying called number until connected.
Apr 1st, 2012
At the moment when I press redial, or select my speed dial, the phone does not show the number called until it actually connects / the first ring-back tone.
Is there a way to change this behaviour?
Phone: 7960.
CUCME 8.5.
Felix
Gajanan Pande Sun, 04/01/2012 - 20:18
  • Cisco Employee,
Felix,
What is the firmware type ( SCCP or SIP ) & version running in 7960 ?
I'd first try upgrading the firmware & see if it helps fixing such cosmetic issue. Latest firmwares can be downloaded from here ( choose the protocol type SCCP or SIP to proceed further ).
GP.
Pls rate helpful posts by clicking on stars below the post !!
ronpatel Sun, 04/01/2012 - 21:06
  • Blue, 1500 points or more
Is it happening to 7960 phones only. Because CME will not display the called number when redialing until the CME sends "alerting" to the calling side. Which means that the other side is ringing which is when users see the redialed number.
What you are seeing it correct way of working.
Ronak Patel
Please rate helpful posts by clicking on stars below the answer
Felix Sarayar Sun, 04/01/2012 - 21:12
Thanks for the replies
@Ronak: I have a feeling that this is expected behaviour as you mention Ronak.
@GP: SCCP 8.0.9. I don't have 7940 to compare, I'll upgrade to 8.1 SCCP to see what happens..
Related Content
