Warning message
SG300 Vlan routing
Apr 1st, 2012
We have recently purchased a SG300 to break up our network which most consists of virtual machines via Bridged networking on network machines. I have created successfully Vlans and the physical machines are capable of communicating across the different subnets that I have created via the SG300 however the Virtual machines can no longer be reached.
Any ideas what I am doing wrong ?
Many Thanks
David Hornstein Tue, 04/03/2012 - 23:13
  • Gold, 750 points or more
Hi Mohammed,
It is really a switch issue or a virtual machine issue.
The following knowledge base article might still be most relevant to you;
http://kb.vmware.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&docTypeID=DT_KB_1_1&externalId=1004109
It asks you to check a few items on your NIC card and virtual machine. You may not be using vmware, but it's also worthwhile checking the manufacturer knowledgebase of your VM software.
regards Dave
turboizzy1986 Wed, 04/04/2012 - 06:28
I have resolved this now,turns out the I could not get to the Firewall from two of the subnets. I have resolved this by adding Static routes on the Astaro firewall for the subnets in question.
Related Content
