WLC 2504 Passive Client feature?
EvaldasOu
Level 4
Level 4
Hello Networkers!
Maybe somebody know, is it possible to use this feature on WLC 2504 ? ( Passive client feature). I found just this note :
" The passive client feature is supported on Cisco 5500 and Cisco 2100 Series Controllers. "
Thanks!
8 Replies 8
Scott Fella
Well I believe that feature was available in 6.x and it is available and works on the 2504 also.
-Scott
Are you sure Scott? That would be great!
Yes I'm sure. I have used it in the past because of Ethernet converters in my clients networks.
-Scott
Thanks a lot for the information
No problem.
-Scott
There is something wrong with this forum, I can't mark your answer as correct with firefox or chrome browsers. :/
Haha.. That's interesting. I think someone else on another thread had that same issue.
Scott Fella
Sent from my iPhone
-Scott
one user reported this issue as will with one of my answers. he was not able to mark it as "Correct Answer".
Rating useful replies is more useful than saying "Thank you"
