Unable to Telnet from router to My PC
Apr 2nd, 2012
Hi All,
I configured the TFTP Server in MY Machine . But when iam trieng to transfer the log from router to PC(TFTP SERVER) it's not hapening.
Then I tried to telnet to port UDP 69. it is not connecting.
below is the only access list that is in my router.
access-list 12 permit 10.10.3.59
access-list 12 permit 10.10.3.61
access-list 12 permit 10.10.3.77
access-list 12 permit 10.10.3.122
access-list 12 permit 10.10.8.157
access-list 12 permit 10.10.3.186
access-list 101 permit ip 10.10.3.0 0.0.0.255 any
access-list 101 permit ip 10.10.8.0 0.0.0.255 any
access-list 101 deny   ip 10.10.4.0 0.0.0.255 any
access-list 101 permit ip 10.10.9.0 0.0.0.255 any
My Machine ip IS 10.10.3.61
Can any one explain the problem...
Roopesh
Richard Burts Mon, 04/02/2012 - 04:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Roopesh
The most common cause of the symptoms that you have is that a firewall is running on the PC and will not allow an incoming connection on port 69. Can you check to see if a firewall is running on the PC? If so, as a test, try to trun off the firewall and see if the TFTP work then.
Rick
Vasileios Boulo... Mon, 04/02/2012 - 04:47
  • Silver, 250 points or more
Roopesh
Maybe you have to check the ip tftp source ip because it is possible to not have routing for the source ip of the tftp packets.
use the next command to your router
ip tftp source-interface
Hope that helps
Vasilis
roopesh.n Mon, 04/02/2012 - 05:56
HI Vasillis,
Thanks for the reply
I have added the command " ip tftp source-interface fasrethernet 0/0 (router inside interface). But result is same
Roopesh
Vasileios Boulo... Mon, 04/02/2012 - 06:33
You can not test udp ports with telnet, only tcp port can be tested via telnet.
So the telnet to port UDP 69 is normal to not work
Check the FWL to your PC for TFTP
Vasilis
Mandlenkosi Nkiwane Mon, 04/02/2012 - 08:27
  • Bronze, 100 points or more
You could have the windows firewall blocking the connection, and below is a link on how you can enable your tftp server to communicate with external sources:
http://windows.microsoft.com/en-US/windows-vista/Open-a-port-in-Windows-Firewall
If you have an anti-virus software, with firewall on it, you will have to look at the logs on that firewall and put the source ip of your switch to be  trusted on the firewall.
I know I have a checkpoint firewall on my home pc and each time I add a device to my home network I have to allow it on that firewall to be able to communicate with my tftp server.
roopesh.n Tue, 04/03/2012 - 02:25
HI All,
But iam able to take backup from my switches and ASA to TFTP Every thing is in my network (10.10.3.0).Problem is ony from Routers Inside interfaces.(Public IP)
Roopesh
