802.1x wireless authentication with certificates
Apr 2nd, 2012
Hi.
I have configured and working 802.1x authentication with certificates for Wired connections. with no problem.
when i try to authenticate the same machine with 802.1x and certificates , on Wirelss, the ACS rejects it  with:
"12520  EAP-TLS failed SSL/TLS handshake because the client rejected the ACS local-certificate."
the ACS is the same, the certificate the same, and the root ca is the same.
what's hapenning????
Antero Vasconcelos
Jatin Katyal Sat, 07/20/2013 - 06:38
  • Cisco Employee,
What supplicant are we using for wireless authentication? Do we have complete chain of certificates installed on the client machine? Can you check if we have root CA/intermediate correctly installed in client and ACS.
~BR
Jatin Katyal
**Do rate helpful posts**
Related Content
