Warning message
AnyConnect VPN and syslog message ASA-3-722035
Last week, my ASA log was filled with following type of syslog message:
%ASA-3-722035: Group  User  IP <208.79.108.41> Received large packet 1374 (threshold 1280)
It appears all of them are from the same user.  I talked to the user and the user didn't express any VPN connectivity issue.
The user mentioned that he was using MiFi card to get Internet (and VPN) service.
My question is what I should do with this syslog message.  Shall I disable this syslog, and change the severity to "informaitonal"?  Or, is it wise to adjust the MTU packet size threshold?
Thanks for any advise.
michael.hollis Tue, 03/31/2015 - 09:12
I'm not sure what to do about this either.  I have one user that is affected by this.
