Any ASA 8.4(3) and VPN Client for Public Internet VPN Configuration Example?
Apr 2nd, 2012
I followed this discussion, I can connect to vpn but failed to access internet and local network device? Would you please let me know how to resolve it?
https://supportforums.cisco.com/docs/DOC-18710
Hugo
Marvin Rhoads Mon, 04/02/2012 - 19:05
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
If you're fuzzy on the CLI setup, just create one using the Remote Access VPN Wizard in ASDM. It'll give you a working setup in under 10 minutes.
hugochengym Mon, 04/02/2012 - 22:52
Marvin
Do you have any idea for CLI configuration example?
Hugo
Marvin Rhoads Mon, 04/02/2012 - 23:10
Do you have an ASA that is otherwise working? You updated your original post to say you tried one config without success. So do you want to troubleshoot that or start fresh? If you want to troubleshoot please tell us what is not working from your first attempt (failure details) and provide the config for review.
If you want to try a different config, it will be more complicated if you have broken bits from your first attempt left over in the config file.
There is a nice example at https://supportforums.cisco.com/docs/DOC-18960 . You can give that a try too.
