SCE 8080 CIR/PIR issue
Apr 2nd, 2012
Hi I create a package in SCABB  with CIR=0, PIR=3500 kbps to have bandwith control over a range of IP address in a csv file directly applied on SCE. but when i review SCA reporter Bandwith service per package, I see  4000Kbps and more in this package. Why the PIR is not working??
Example:
csv file:
client1, 1.1.1.0/24, 5
Package in SCABB:
index: 5
CIR = 0
PIR = 3500
Tomonobu Okada Sat, 04/07/2012 - 08:35
Hello Geovanny,
Is this production environment or lab?
What kind of traffic passing through the SCE?
(Num of flows, src IPs, TCP/UDP, applications, etc.)
One possible explanation for this is that since the traffic control
starts only after the classification is completed, those pre-classified
traffic is not controlled. This is usually not a problem but some P2P
protocols may require many packets to be inspected to classify and
if there is a heavy P2P user, the traffic for the user may exceed the PIR
slightly.
I think you can check which protocol is exceeding the PIR by looking
at the report which you realized the issue.
Tomo
