unable to ping vip on ACE ,in routed mode
Answered Question
Apr 2nd, 2012
Configured ACE in routed mode ,and have the vlan ,route-map defined on th switch.
Able to ping the server vlan ,and servers from the ACE ,but unable to ping the vip from ACE ,but able to ping the gateway for the client vlan.
Attaching the config the of the switch and the ACEs
From the Switch I am able to ping the vip , but  not from ACE or from my PC.
Correct Answer by sivaksiv about 5 years 4 months ago
You said the ping from switch to ACE works. So check if you are able to ping the switch from your PC. I suspect there is some routing issue which can be resolved by further troubleshooting in the network.
Siva
Overall Rating: 5 (1 ratings)
sivaksiv Mon, 04/02/2012 - 20:59
  • Cisco Employee,
This is an expected behaviour.
We don't allow ping to VIP within ACE but you should be able to ping from switch or
from client.
Siva
kalugotla1 Mon, 04/02/2012 - 21:16
How come I am unable to ping from my machine ,as I get request timed out ,using my PC to test the vip ,but getting request timed out
Can you please let me know ,whether my configuration on the switch and the ACE is correct ,I mean access-list ,route-map statements on the switch and
the default route on ACE.
Correct Answer
sivaksiv Mon, 04/02/2012 - 21:19
  • Cisco Employee,
Siva
