Warning message
Cisco 1941 Router Upgradation
Apr 3rd, 2012
Hi Experts,
While upgrading Cisco 1941 router with latest IOS version, my router gone to the rommon mode.
Below is the out put of in the rommonitormode.
rommon 47 > dir flash:
program load complete, entry point: 0x80803000, size: 0x1b340
Directory of flash:
2      65409024  -rw-     c1900-universalk9-mz.SPA.151-3.T1.bin
11188    2903      -rw-     cpconfig-19xx.cfg
11189    2941440   -rw-     cpexpress.tar
11908    1038      -rw-     home.shtml
11909    115712    -rw-     home.tar
11938    1697952   -rw-     securedesktop-ios-3.1.1.45-k9.pkg
12353    415956    -rw-     sslclient-win-1.1.4.176.pkg
17238    65409024  -rw-     c1900-universalk9-mz.SPA.152-3.T.bin
rommon 48 >
rommon 48 > boot flash:c1900-universalk9-mz.SPA.152-3.T.bin
loadprog: error - on load of image from file system with monlib
Image size (65409024) does not match the expected size (66415436)
boot: cannot load "flash:c1900-universalk9-mz.SPA.152-3.T.bin"
rommon 49 >
In flash i have IOS, while using boot command above error is showing. Please help to solve this issue.
Janardhan
Neeraj Arora Tue, 04/03/2012 - 05:14
  • Silver, 250 points or more
Hi Janardhan ,
It seems that the IOS file (15.2.3T) that you are trying to load has gone bad/corrupt. I would suggest you try to boot with the other IOS image that you have in flash and copy the latest IOS file again.
Use the command:
rommon 48 > boot flash:c1900-universalk9-mz.SPA.151-3.T1.bin
After the router boots up with this old IOS, download the latest IOS or the same IOS 15.2.3T again and copy it to the flash following the IOS upgrade procedure.
Try this and provide an update if this helps
Neeraj
