Warning message
CUCM ' route plan report' equivalent for Unity Connection
Answered Question
Apr 3rd, 2012
Hello Guys
One of the biggest problems I have had with Unity Connection is that I have not seen a function that is equivalent of CUMC ‘route plan report ‘ nor ‘ dependency records’. That would make troubleshooting faster.
Guys when it comes to Cisco unity connection, how do you go about finding dependency records / finding out all the things that are associated with a particular DN or object as you would do in CUCM.
Correct Answer by Rob Huffman about 5 years 4 months ago
Hi Max,
From the Unity/Unity Connection guru Lindborg
https://supportforums.cisco.com/message/3047374#3047374
Another great reporting tool is CUDD - Connection User Data Dump
http://www.ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm
Cheers!
Rob
PS: ATM is an awesome tool along with many others developed
by Jeff and his team.
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 04/03/2012 - 05:22
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Max,
Cheers!
Rob
Sarg . Sat, 04/14/2012 - 06:24
really helpful, cheers
rob, what if i wanted find dependency records for Unity version 5x what do i use?
Rob Huffman Sat, 04/14/2012 - 10:06
  • Hall of Fame,
    Founding Member
Hi Max,
Good stuff my friend
For Unity 5.x there is this version of ATM that can do dependency reports;
http://www.ciscounitytools.com/Applications/Unity/ATM4x/Help/AudioTextManager.htm#_Toc122397239
Dependency Report Option
Version 5.0.23 of ATM introduced the option to view a dependency report for a selected call handler, interview handler, subscriber or name lookup handler.  This simple text based report shows all references to the selected object.  This can be useful if you plan to delete the object and you want to make sure to fix up links to it before you remove it.
To access the Dependency report, select the Grid View tab and right click on any call handler, name lookup handler, interviewer or subscriber in the grid.  The option “Dependency Report” will be available for you to select.  This launches a separate form which displays the report output.  You can save the output to a text file or copy it to the clipboard for reference.
NOTE: This feature is only available for Unity 4.0(1) and later systems.
Cheers!
Rob
