Switchport flapping with HP (Static) printer attached
Apr 3rd, 2012
Hello there,
As you can no doubt see I am new to this community. I currently have what I "hope" is a simple question.
(Setup Cisco 1841 router with X2 Cisco 2960 Catalyst switchesconnected)
We currently have a scenario on a Cisco 2960 Catalyst switch with a printer connected to a port on our VLAN1 (A static, non DHCP VLAN)
whereby when the HP network printer is attached the printer resets itself every 20 seconds or so. The actual printer is supported by
another company and unfortunately I don't have either telnet (from our router) or web access to the printer, but the company who supplied
the printer are stating the issue is being brought about by either our router or switch and that the printer has been replaced. I believe
they just configure the printers locally with the just the static IP, the DG and the subnet mask for our network, all I believe to be configured
correctly.
So in summary, a HP printer which has been replaced is connected to any port assigned to VLAN1 on either of the connected switches,
configured locally with the IP,SM and DG and as soon as those settings are applied, the printer continually resets itself. So from the switch
side, all I can see is:
Apr  3 12:36:42: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, cha
nged state to down
Apr  3 12:36:43: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to down
Apr  3 12:37:09: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to up
Apr  3 12:37:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, cha
nged state to up
Apr  3 12:37:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, cha
nged state to down
Apr  3 12:37:35: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to down
Apr  3 12:38:01: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state to up
Has anyone come across this before ? Any suggestions as to what I can change on the switch or router to prevent this ?
yjdabear Tue, 04/03/2012 - 12:22
  • Gold, 750 points or more
Provided it's supported by your device's hw and IOS, you could either disalbe such syslog messages "per-interface" (recommended for the average access ports) or "globally" (not recommended, since you probably want to keep tabs on critical interfaces such as uplinks):
! per-interface
no logging event link-status
! globally
no logging event link-status default
Puxster1979 Tue, 04/10/2012 - 02:57
Thanks yjdabear,
This issue wasn't that I wanted to ignore or remove the log entries, rather stop what ever was causing the issue. After removing all other devices from that VLAN by shutting down the various switch ports they were connected to the issue stopped, so we could soon localise a mis-configured device on the same network which was causing the printer to continually reload.
Cheers.
Related Content
