configure backkup PSTN for WAN link on CUCME
Answered Question
Apr 3rd, 2012
I have 2 CUCME in 2 different Sites and connected with IPSEC VPN Wan Coonection and PSTN (FXO)
The dial plan of the Site-1 is 100x and Site-2 is 200x .
The Site-1 FXO line is 22513612 and the The Site-2 FXO line is 24576022
They are working fine through the WAN Link (Voip) but i'd like to configure The PSTN to be backup for the wan link without changing the Dial Plan
I need help in  the Config
Correct Answer by paolo bevilacqua about 5 years 4 months ago
With the proposition expressed by your nickname, you should have no problem in reading user documentations.
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/dialpeer/configuration/15-0m/vd-dp-overview.html
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 04/03/2012 - 09:57
  • Hall of Fame,
    Founding Member
Just tse lower preference dial-peer(s) for the same patters.
