L4 Configuration
Answered Question
Apr 3rd, 2012
How do you physically configure a network tap on the Ironport? I'm not sure what they are referring to... I'm hoping they are not talking about a pass through fromt he inside firewall to the switch.
Correct Answer by Ken Stieers about 5 years 1 month ago
In order to make my example clear, I'm going to make the following assumptions:
     You're talking about the Layer 4 Traffice Monitor (aka L4TM)
     Firewall inside interface, the WSA P1 interface and the WSA T1 interface plugged into the same swtich, on the same VLAN.
     Firewall inside on gig1/1
     WSA P1 on gig1/5
     WSA T1 on gig1/10
     (Optional WSA T2 on gig1/11)
If you feel that one interface on the WSA will get overloaded, set the L4TM config in Network/Interfaces for simplex. Then connect the WSA T2 port to the swtich (say gig1/11), and do an egress span from gig1/1 to gig1/10 and ingress span from gig1/1 to gig1/11.
If its all connected to a HUB, the use DUPLEX on the WSA L4TM config and just hook up T1...
Or you can use an actual tap, that you put in-line like this:  http://www.netoptics.com/products/network-taps/101001000baset-tap and hook that up to the T1/T2 ports as appropriate.
Hope that helps!
Ken
Overall Rating: 5 (1 ratings)
Correct Answer
Ken Stieers Tue, 04/03/2012 - 11:24
  • Gold, 750 points or more
     WSA P1 on gig1/5
     WSA T1 on gig1/10
Hope that helps!
Ken
phretbuzz Tue, 04/03/2012 - 20:11
OK. so it sounds like the network tap is an efficient piece of hardware to deliver packets. Thanks
