HP DAC Copper Cable with Cisco 4900M
Answered Question
We have HP C7000/VC-Flex 10 Module  that I would like to connect to our Netapps NFS datastore.  The Cisco  switch that I will be using between HP Flex-10 and Netapps is Cisco  4900M.  I have a HP cable AP784A direct attach copper SFP+ to SFP+.   Which module I need to purchase and insert into my 4900M to support 10Gb  connectivity via HP DAC 10Gb cable.
Please Advise!
Correct Answer by krun_shah about 5 years 3 months ago
You need
4900M 4 port 10GE half card with X2 interfaces (WS-X4904-10GE)
    OR
4900M 8 port 10GE half card with X2 interfaces (WS-X4908-10GE)
WITH
Cisco OneX Converter Module Converts an X2 Interface into One SFP+ Interface (CVR-X2-SFP10G)
I would recommend you to use following DAC cables from Cisco.
• SFP-H10GB-CU1M: 10GBASE-CU SFP+ Cable 1 meter (Version -02)
• SFP-H10GB-CU3M: 10GBASE-CU SFP+ Cable 3 meter (Version -02)
• SFP-H10GB-CU5M: 10GBASE-CU SFP+ Cable 5 meter (Version -02)
Overall Rating: 5 (1 ratings)
Correct Answer
krun_shah Thu, 04/05/2012 - 06:05
  • Bronze, 100 points or more
You need
    OR
WITH
