CUPS Federation Load Balancing
Apr 4th, 2012
Hi All,
Need to setup the interdomain CUPS federation with Lync Server. From the federation guide, it says that the only way for High Availability on the CUPS side is to use a Cisco CSS (as it is the only one that supports TLS).
As the CUPS cluster has two nodes, is it supported to instead use Cisco ACE module in the 6500 for load balancing (Lync supports only a single IP)?
Thanks in advance,
Addy
Related Content
