Warning message
Transfer to CUE issue--no original calling number when listening to voicemail
Answered Question
Apr 4th, 2012
I do a transfer and then call forward all to CUE voicemail, but after this when I leave a message it can't show as from original calling number.
For example: 2223 call 2222, 2222 presss *2222 forward it to cue, then 2223 leave a message,  but when 2222 listen to the message  it was not from 2223, but from itself (2222)
configuration as follow:
voice translation-rule 1
rule 1 /^\*2222$/ /2222/
voice translation-profile transfervm
translate redirect-called 1
dial-peer voice 6666 voip
translation-profile outgoing transfervm
destination-pattern 6666$
session protocol sipv2
session target ipv4:10.128.1.1
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn  9
number *2222
call-forward all 6666
Correct Answer by paolo bevilacqua about 5 years 4 months ago
If there was another solution, I would have told you so.
Thanks for the nice rating and good luck!
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 04/04/2012 - 05:28
  • Hall of Fame,
    Founding Member
This happens because on regualar consultation transfers, like the one 2222 does in your example, CME sends as calling number, the extension number instead of original calling number.
You can add a softkey TransferVM to softkey connected, enter mailbox destination, hangup. That will make VM to carry over the original calling number.
Bossearth Wed, 04/04/2012 - 05:38
thanks a lot!
but if there is another solution, I just want to use softkey"Transfer" and the 6th line button to perform this task, is it possible?
Correct Answer
paolo bevilacqua Wed, 04/04/2012 - 06:55
  • Hall of Fame,
    Founding Member
