Query regarding CME Extension mobility configuration
Apr 4th, 2012
Hi team,
From what I have read in the "voice user-profile" configuration we give number <dn> type <ring-type>. The dn here is the extension number. My doubt here is if different ephone-dns have the same number, how can we distinguish them.
Multiple ephone-dn can have same number. "user profile" configuration is asking for only the number. How can we tell which ephone-dn it belongs to. Basically, if we want to use the call hunt feature (using preference and huntstop commands), where same number will be used by different ephone-dns and differerent ephone-dns with same number should be assigned to users so that the call rings on 1 user phone after the other (instead of all phones at same time which happens if all numbers belong to same ephone-dn), how can I achive with user-profile/extension mobility configuration.
Swati
swati-singh Thu, 04/05/2012 - 03:45
Could you please help me here. Please let me know if the question is not clear.
Swati
anchoudh Thu, 04/05/2012 - 08:14
  • Red, 2250 points or more
Hi Swati,
If you run the Show run command it will display the eintire congif on the CME.
ephone x is mapped to specific MAC ids of the phones and also with specific buttons, and than later on you will map the ephone-dn x to a specific number (Directory Number).
As shown below.
c3825(config) #ephone 1
      c3825(config-ephone) #mac-address 000D.BDB7.AE4A
      c3825(config-ephone) #type 7960
      c3825(config-ephone) #button 1:1
      c3825(config-ephone) #exit
      c3825(config) #ephone-dn 1
      c3825(config-ephone-dn) #dual-line
      c3825(config-ephone-dn) #number 2222 1
      c3825(config-ephone-dn) #allow watch
      c3825(config-ephone-dn) #exit
You need to do a reverse check here. From Number to ephone-dn and than to button and than to phone MAC.
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answer !!
swati-singh Fri, 04/06/2012 - 23:11
Hi Anand,
But, my question is: When the same Number is used by multiple ephone-dns, to which ephone-dn should I map the number?
I am asking about the Extension mobility configuration:
voice user-profile 4
user addepall password 1234
number 50004 type normal
and both ephone-dn 111 ans 112 use the same number
ephone-dn  111  octo-line
number 50004
ephone-dn-template 1
ephone-dn  112  octo-line
number 50004
How should I mention in the user-profile configuration that the number 50004 is dn 111 and not 112? In extension mobility, phones/mac addresses will not have any button configuration. Users should login to their profile to get their buttons.
Swati
