Warning message
Is the vPC "peer-switch" command intrusive ?
Apr 4th, 2012
As per the discussion topic, I need to enable vPC "peer-switch" command on a pair of Nexus 7018s which are currently vPC peers (primary and secondary). The STP root and Secondary root are currently configured  across these switches.
Can I enable the peer-switch command in this configuration without impacting services, and then modify both switches to have the same bridge priority without impacting services ?
We have a few downstream 5ks which are not dual homed to both vPC peers (work in progress) so need to understand if the peer-switch command will in any way break this connectivity for now.
Thanks.
mikegrous Wed, 04/04/2012 - 06:05
When i enabled it on my nexus 7Ks, it caused no inturruption.
