Warning message
install LMS 3.0 on VM
Answered Question
Apr 4th, 2012
Hi all
I have CWLMS-3.0-5K-K9 with licence file but I can't install it in the VM ( the version didn't support
virtualisation vmware) .
Is there any way to install it or other version with same licence?
Thanks in advance.
Correct Answer by yjdabear about 5 years 4 months ago
You can download LMS 3.2.1 and apply your LMS 3.0 license there. LMS 3.2 has virtualization support:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1099303
"The following Virtualization systems are supported in LMS 3.2:
VMware ESX Server 3.0.x
VMware ESX Server 3.5.x
VMware ESXi 3.5 Update 2
VMware ESX Server 4.0.x
VMware ESX Server 4.1
VMware ESXi Server 4.0
VMware ESXi Server 4.1
Hyper-V Virtualization "
Correct Answer by Martin Ermel about 5 years 4 months ago
your license for LMS 3.0 is valid for LMS 3.2, also. LMS 3.2 is supported for installation on VMware ESX and Hyper V, see this document:
after installing LMS 3.2 you should update to LMS 3.2.1.
Overall Rating: 5 (2 ratings)
Correct Answer
yjdabear Wed, 04/04/2012 - 13:27
  • Gold, 750 points or more
mostafa ouamou Thu, 04/05/2012 - 03:28
Hi all
thanks for your reply.
Can'I install 3.2.1 directely or we should install 3.2 and update to 3.2.1?
Thanks.
Martin Ermel Thu, 04/05/2012 - 05:05
  • Blue, 1500 points or more
you need to install LMS 3.2 first and update to LMS 3.2.1 afterwards by applying the service pack1;
here is a link to the README of the Service Pack 1
