Warning message
SSH v1.99 VS v2.0
Apr 4th, 2012
  • Blue, 1500 points or more
hi all,
is there a really big difference between the two SSH versions? i initially thought that version 1.99 is "the" 2.0.
Router#show ip ssh
SSH Enabled - version 1.99
Authentication timeout: 120 secs; Authentication retries: 3
Router1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router1(config)#ip ssh version 2
Router1(config)#end
Router1#show ip
*Apr  5 10:11:02.123: %SYS-5-CONFIG_I: Configured from console by console
Router1#show ip ssh
SSH Enabled - version 2.0
Overall Rating: 5 (1 ratings)
darren.g Wed, 04/04/2012 - 22:07
  • Silver, 250 points or more
johnlloyd_13 wrote:
hi all,
Router#show ip ssh
Router1#conf t
Router1(config)#end
Router1#show ip
Router1#show ip ssh
SSH version 1.99 is merely an indication that the server supports both SSH version 2 *and* SSH version 1.
It's not really a version, as such, but an indication of backward compatibility.
See
http://en.wikipedia.org/wiki/Secure_Shell
By seting your SSH config to V2, you're disabling V1 backward compatibility (not necesarily a bad thing, given V1's well-known and documented security holes).
Cheers.
Related Content
