ASA 5520 ver 7.0(1) upgrade
Apr 4th, 2012
Hiii Cisco,
could you please provide me with the importnant links which can show me how to do the software upgrade for my ASA 5520 ver 7.0(1) to ver 8.4 ? as well as the ASDM
Appreciate your support
varrao Wed, 04/04/2012 - 23:21
Please make sure you have the hardware requirements in place for it, this link would give you all the information required for it:
https://supportforums.cisco.com/docs/DOC-12690
Also you can follow this link to upgrade the ASA software:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008067e9f9.shtml
If in Failover:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080b20f35.shtml
Hope that helps.
Varun
fadimabrouk Thu, 04/05/2012 - 01:50
Hiii Varun,
currently my ASA ver 7.0(1) so below is my plan to do this upgrade:
7.0(1)       to 7.2(1)         to 8.0(2)     to 8.2(2)         to 8.3(2)          to 8.4(3)
is this will work with me??
on the document that you gave it's like below
varrao Thu, 04/05/2012 - 02:29
Yes, the upgarde path given is correct and the recommended one. You can follow it.
Varun
fadimabrouk Thu, 04/05/2012 - 04:34
Hiii Varun,
it's working perfectly, but why i can't connect via SSH or ASDM? i'm using my laptop and connect directly to interface 0/1 and SSH enable and i'm able to ping this interface. (also from ASA i can ping my laptop) but unable to access it via ASDM or even CLI "SSH"
can i know where else i need to check to access the device via ASDM? note that currently ASA software ver 8.4(3),  ASDM image: 6.4(7)
i still can access my ASA via console
please Advise
varrao Thu, 04/05/2012 - 04:41
Hi Fadi,
Difficult for me to tell, but yes a few pointers that I can give:
Check "show run asdm", it should have the new ASDM image set asdm-647.bin...
Check "show run http", it shud have the correct settings.
For SSH:
Try "show run ssh", right configujration should be there.
Try generating the crypto keys again.
For ASDM, open the browser and type the url https://a.b.c.d    and then check.
Hope that helps.
Varun
fadimabrouk Sun, 07/08/2012 - 00:26
Hiiii guys
i have my ASA5520 running on ASA softwarer 8.4(3) i want to upgrade it to 8.4(4.1)   what's the steps? i can do it using ASDM  right?  i have two ASA in failover mode so i don't think this will be a matter
Appreiatce your help in that
nkarthikeyan Sun, 07/08/2012 - 09:14
