alialjamri2008 Thu, 04/05/2012 - 02:43
switch(config-if)#bandwidth ?
  <1-10000000>  Bandwidth in kilobits
  inherit       Specify how bandwidth is inherited
Ali
alialjamri2008 Thu, 04/05/2012 - 03:28
Sorry, the one I mentioned above is used only to manipulate the metric, please read below:
How do I configure a bandwidth limit?
In the Cisco IOS on a Catalyst switch (not on a router), there’s an Interface Mode command called shape round-robin queue bandwidth. More specifically, the command is srr-queue bandwidth.
This command has been around since IOS 12.2(25). For these examples, I’m using a Cisco Catalyst 2960 switch.
Entering the command appended with a question mark will display the command options. Here’s an example:
Switch(config)# interface FastEthernet 0/1
Switch(config-if)# srr-queue bandwidth ?
  limit              Configure bandwidth-limit for this interface
  shape             Configure shaping on transmit queues
  share              Configure shared bandwidth
As you can see, the command options are limit, shape, and share. While we’ll focus on the limit option this time, keep in mind that you can also use the srr-queue bandwidth command to shape and share bandwidth.
For example, let’s say you have a 100-Mb Ethernet port on a Catalyst switch. You’re selling the bandwidth on the port, and a customer has bought 10 Mb of bandwidth. Obviously, you want to limit the outbound bandwidth on the port to 10 Mb instead of the full 100 Mb.
To do so, go to Interface Configuration Mode on the switch port, and apply the srr-queue bandwidth limit command. Here’s an example:
Switch(config-if)# srr-queue bandwidth limit 90
The 90 sets the outbound bandwidth limit on the port to 90 percent of the port speed. Since this is a 100-Mb port, this should limit the outbound traffic from the port to 10 Mb.
Ali
vishalpatil86 Thu, 04/05/2012 - 04:26
hi,
i would like to know giving speed limit to gig port...
commands u mentioned work with fastethernet port only
vishalpatil86 Thu, 04/05/2012 - 05:41
hi ali,
forgot to mention the model of switch,, its 4506e with which the command is not working...
is there any other way like qos to limit the bandwidth on 4506e
alialjamri2008 Thu, 04/05/2012 - 06:39
Ok , if this command is not working on 4500, you probably need to configure QoS, no idea?
Ali
vishalpatil86 Thu, 04/05/2012 - 07:43
yes, i dont have any idea about qos...
can u help me to sort this out??
ahmed-naguib Thu, 04/05/2012 - 02:58
Hello
if you would like to set the speed of the switch port you can use the following
conf t
int GigabitEthernet 1/0/1
speed (10,100,100 or Auto)
you can use the auto to let the switch decide negotiate the speed with the other switch .
