CRS-1 plaspa port and jacket slot
Answered Question
Apr 5th, 2012
Hi Expert,
I need to replace SPA card to resolve the error
%L2-PLIM_ASIC-4-HW_WARNING : plaspa instance 0: (plaspa port 2 jacket slot 0) RSI Spi Error was reported
The plaspa port 2 jacket slot 0 would be SPA slot 0 (0/0/0), correct?
NAME: "0/PL0/*", DESCR: "Cisco Carrier Routing System SPA Interface Processor Card"
PID: CRS1-SIP-800      , VID: V04
NAME: "0/0/0", DESCR: "2-port OC48/STM16 POS/RPR Shared Port Adapter"
PID: SPA-2XOC48POS/RPR , VID: V02
NAME: "POS0/0/0/0", DESCR: "OC48 SR/STM16 I-16"
PID: SFP-OC48-SR         , VID: V01 ,
NAME: "POS0/0/0/1", DESCR: "OC48 SR/STM16 I-16"
NAME: "0/0/2", DESCR: "2-port OC48/STM16 POS/RPR Shared Port Adapter"
Thank you for all replies
Correct Answer by Alexei Kiritchenko about 4 years 12 months ago
If the power we get is too low, replacement won’t fix it either.
  1. Use a power meter to confirm the power level you receive.
  2. Find out the power budged for this cable. It should have been provided by your carrier.
  3. Verify with the carrier that is their Tx power level
/A
Overall Rating: 5 (8 ratings)
Alexei Kiritchenko Thu, 04/05/2012 - 03:05
  • Cisco Employee,
Hi Roger,
RSI Spi Error errors may appear when there are SONET errors on the POS interface. You may want to verify the line first.
/A
Rojer-bkk Thu, 04/05/2012 - 03:22
I encounter the RSI SPI error incrementing if i issue show controller plim asic plasspa error location 0/0/CPU0
RSI SPI error              5020800
RSI SPI error              5020881
RSI SPI error              5020897
RSI SPI error              5020902
Alexei Kiritchenko Thu, 04/05/2012 - 03:25
  • Cisco Employee,
Yes, it can be failed SPA, but a probability is higher that there are just SONET errors.
Look at ‘show controller SONET 0/0/0/x’ and verify all the interfaces for any increasing errors.
/A
Rojer-bkk Thu, 04/05/2012 - 03:33
I didn't see any errors on SONET interface from command show controller SONET 0/0/0/0 and 0/0/0/1
RP/0/RP0/CPU0:TH-ICR-TT1#sh controller SONET 0/0/0/0
Thu Apr  5 17:29:23.737 GMT
Port SONET0/0/0/0:
Status: Up
Loopback: None
SECTION
  LOF = 38         LOS    = 20                           BIP(B1) = 2761538
LINE
  AIS = 4          RDI    = 63         FEBE = 21712298   BIP(B2) = 6871279
PATH
  AIS = 112        RDI    = 441        FEBE = 674410     BIP(B3) = 4673236
  LOP = 62         NEWPTR = 422        PSE  = 10093      NSE     = 17398
  PLM = 136        TIM    = 60         UNEQ = 0
Line delays trigger:      0 ms clear:  10000 ms
Path delays trigger:      0 ms,      0 ms (configured), clear:  10000 ms
Last clearing of "show controllers SONET" counters never
Detected Alarms: None
Asserted Alarms: None
Mask for Detected->Asserted: None
Detected Alerts: None
Reported Alerts: None
Mask for Detected->Reported: None
Alarm reporting enabled for: SLOS SLOF SF_BER PLOP
Alert reporting enabled for: B1-TCA B2-TCA B3-TCA
Framing: SONET
SPE Scrambling: Enabled
C2 State: Stable   C2_rx = 0x16 (22)   C2_tx = 0x16 (22) / Scrambling Derived
S1S0(tx): 0x2  S1S0(rx): 0x2 / Configured
PATH TRACE BUFFER : STABLE
  Remote hostname : SG-ICR-GS1
  Remote interface: POS0/0/0/1
  Remote IP addr  : 122.144.20.28
APS
No APS Group Configured
  Rx(K1/K2) : 0x00/0x00
  Tx(K1/K2) : 0x00/0x00
  Remote Rx(K1/K2): 01/0   Remote Tx(K1/K2): 01/0
BER thresholds:  SF = 10e-3  SD = 10e-6
TCA thresholds:  B1 = 10e-6  B2 = 10e-6  B3 = 10e-6
  Optics type: OC48 SR/STM16 I-16
  Clock source: internal (actual) internal (configured)
  Rx S1: 0x2  Tx S1: 0x0
Optical Power Monitoring (accuracy: +/- 1dB)
  Rx power = 0.0032 mW, -24.9 dBm
  Tx power = 0.2181 mW, -6.6 dBm
  Tx laser current bias = 22.0 mA
Alexei Kiritchenko Thu, 04/05/2012 - 03:40
  • Cisco Employee,
these sesion shows errors:
SECTION
LINE
PATH
verfiy if they are increasing.
Rojer-bkk Thu, 04/05/2012 - 03:48
Thanks. I found BIP(B1), B2, B3 value increasing
  BIP(B1) = 2761803 BIP(B2) = 6871541 BIP(B3) = 4673494
  BIP(B1) = 2761806 BIP(B2) = 6871544 BIP(B3) = 4673497
  BIP(B1) = 2761823 BIP(B2) = 6871561 BIP(B3) = 4673514
  BIP(B1) = 2761823 BIP(B2) = 6871561 BIP(B3) = 4673546
Anway, the error messages was reported almost every hour
%L2-PLIM_ASIC-4-HW_WARNING : plaspa instance 0: (plaspa port 2 jacket slot 0) RSI Spi Error was reported l be logged
Alexei Kiritchenko Thu, 04/05/2012 - 03:59
  • Cisco Employee,
RSI errors are not 1:1 linked to SONET errors, but errors on the line can cause some RSI errors to appear.
We have B1 errors already, they show we have a problem between this interface and the first connected carrier device. That has to be addressed first.
/A
Rojer-bkk Thu, 04/05/2012 - 04:02
you mean replace the SPA card will not resolve the error?
Alexei Kiritchenko Thu, 04/05/2012 - 04:35
  • Cisco Employee,
There is a small possibility that the physical B1 errors are caused by failed SPA or XFP, but I would not start with that as probability is low.
A simple test,
  1. schedule a maintenance window
  2. put a physical loopback on the SONET 0/0/0/0 (connecting Rx with Tx by one cable).
  3. Use ‘sh controller SONET 0/0/0/0’ to monitor for B1 errors. We should not see any. And if we don’t when this SPA is OK
btw, which exactly XFP do you use? I see we have Rx power -24.9 dBm. It may be too low for some XFPs.
/A
Rojer-bkk Thu, 04/05/2012 - 05:02
The error could be from SPA card or SPF even carrier devices. If we can prove the SPA card is ok so we have to check SFP POS0/0/0/0 for next step?
Rojer-bkk Thu, 04/05/2012 - 05:39
I agree with you. I will try to replace SPF-OC48-SR first.
Correct Answer
Alexei Kiritchenko Thu, 04/05/2012 - 05:45
  • Cisco Employee,
/A
Rojer-bkk Sun, 04/22/2012 - 21:56
Hello Alexei,
The problem can be solved with you advised. Many thanks!!!
Rojer-bkk Mon, 04/23/2012 - 05:50
Can i monitor Tx/Rx power via SNMP? if yes, please let me know MIB to me? Thanks
Alexei Kiritchenko Mon, 04/23/2012 - 12:02
  • Cisco Employee,
That is not implemented on CRS.
/A
Sudhir Kumar Fri, 05/04/2012 - 05:40
  • Cisco Employee,
Hello Alexei
What is plaspa port ? can you please give me an idea for it ?
thanks
sudhir
Alexei Kiritchenko Sat, 05/05/2012 - 13:05
  • Cisco Employee,
PLA stands for PLIM LINK ASIC. PLASPA used on the SIP card for CRS and it is the interface controller for the PLIM.
In the ingress direction it takes all the traffic coming from the different ports on the PLIM and places them into virtual queues.
In the egress direction it takes all the traffic from the EgressQ ASIC buffers it and then transmits it to the appropriate egress port.
/A
