3ware CLI
Answered Question
Apr 5th, 2012
I need some help with the Raid 5 array. I had two disk drives fail and now the raid-5 is Inoperable. I have been reading the AMCC Storage 3ware CLI guide, but I can't figure out how to add the drives I replace to the Raid Unit. Does anyone know how to do this?
//csit-svr-cam-8> //csit-svr-cam-8> /c2 show
Unit  UnitType  Status         %RCmpl  %V/I/M  Stripe  Size(GB)  Cache  AVrfy
u0    RAID-5    INOPERABLE     -       -       64K     4656.51   OFF    OFF
Port   Status           Unit   Size        Blocks        Serial
p0     OK               u0     465.76 GB   976773168     9QGA22LV
p1     OK               u0     465.76 GB   976773168     9QM0EHKW
p2     OK               u0     465.76 GB   976773168     9QM0EVJN
p3     OK               -      465.76 GB   976773168     9WJ1M0ZH
p4     OK               u0     465.76 GB   976773168     9QM0G9DP
p5     OK               u0     465.76 GB   976773168     9QM0FQKT
p6     OK               -      465.76 GB   976773168     9WJ1LRP9
p7     OK               u0     465.76 GB   976773168     9QM0CBPN
p8     OK               u0     465.76 GB   976773168     9QGA26D8
p9     OK               u0     465.76 GB   976773168     9QM0GBYR
p10    OK               u0     465.76 GB   976773168     9QM0FQSA
p11    OK               u0     465.76 GB   976773168     9QM0E7TJ
Correct Answer by harsandh about 4 years 11 months ago
  1. The server had lost 2 drives. They are not showing with any unit ID
  1. We did a delete partitions
/c2/u0 del
Do a show to see if it deleted properly
/c2 show
  1. Then build the raid
/c2 add type=raid5 disk=0-11
  1. Do a show and it should show initializing. This is background init.
/c2 show
  1. Exit out of tw_cli,
  2. ---------------------------------------------------------------------------------
  3. Do a cat/proc/partitions to see partitions showing up
cat/proc/partitions
  1. Create filesystem
parted /dev/sdb mklabel gpt
  1. Do a print to see the filesystem
parted /deb/sdb print
  1. Make the sdb partition into an xfs filesysem
parted -- /dev/sdb mkpart primary xfs 0 -0
  1. Do a print to check filesystem again
parted /dev/sdb print
  1. Now  format the disk
mkfs –t xfs –f /dev/sdb1
  1. Then mount the disk
mount /dev/sdb1 /media1
  1. Put entry for media1 in fstab (use vi or whatever)
vi /etc/fstab
  1. Then do an unmount and mount, test filesystem table entry
umount /media1
mount /media1
Overall Rating: 5 (1 ratings)
Correct Answer
harsandh Thu, 04/05/2012 - 15:49
  • Cisco Employee,
/c2/u0 del
/c2 show
/c2 show
cat/proc/partitions
vi /etc/fstab
umount /media1
mount /media1
