Warning message
etherchannel and load balancing method for non ip traffic
Answered Question
Apr 5th, 2012
  • Bronze, 100 points or more
Hi everybody
How is everybody?
My book says if a switch is configured with "port-channel load-balance src-dst-ip"  and it receives a non ip frame say sna, then it will fall back to" next lowest" method.
My question is: "How are these mehods  arranged from  higest to lowest?
thanks and have a great weekend
Correct Answer by Reza Sharifi about 5 years 4 months ago
Hi Sarah,
The load balancing is different for different series of switches.  For example, by default the 6500 series support source/destination ip for ip packet and source MAC address for non-IP packets.  On the other hand, the 3750 series by default support source MAC address for both IP and non-IP  packets.  Of course, this can be changed.
Here is the output from a 3750:
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source MAC address
  IPv4: Source MAC address
  IPv6: Source MAC address
Switch#
and here are the options:
Switch(config)#port-channel load-balance ?
  dst-ip       Dst IP Addr
  dst-mac      Dst Mac Addr
  src-dst-ip   Src XOR Dst IP Addr
  src-dst-mac  Src XOR Dst Mac Addr
  src-ip       Src IP Addr
  src-mac      Src Mac Addr
have a nice weekend
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Thu, 04/05/2012 - 20:33
  • Cisco Designated VIP,
    2017 LAN
Hi Sarah,
Switch#
  dst-ip       Dst IP Addr
  src-ip       Src IP Addr
have a nice weekend
sarahr202 Fri, 04/06/2012 - 06:12
Thanks Reza.
If a switch configured with dst ip and receives a SNA frame,  what method will switch use?  My book says the switch uses from highest to lowest method in such case.
Is the list you have provided, arranged  from highest to lowest methods ? ( For e.g if a switch configured with src ip add, will use src mac if it receives a sna frame b/c it is listed right below src ip address in your list)
I have few more questions
1) If we have an etherchannel consisting of f1/1 f1/2 with mac1 and mac2 respectively. and etherchanel is acting as a trunk using isl .My question is what will be the src mac address used in ISL header ?
2)  If we have  a multilayer switch with layer 3 etherchannel consisting of f1/1 f1/2, what would be the mac addressed used by etherchannel acting as layer 3 port?
3) Do routers support PaGp or LACp ?
