IPv4 VPN with IPv6 peers not working
Apr 6th, 2012
Hi everybody,
I'm running a lab with GNS3 which is composed of 2 ASA's (8.4.2) and one host behind each ASA.
In this lab I want to set up a Lan-to-Lan VPN with both peer in IPv6, and internal networks still IPv4. (both peers are in dual-stack)
According to the Cisco documentation it should works :
"Specifically, the following topologies are supported when both peers are Cisco ASA 5500 series adaptive security appliances: [...]
The adaptive security appliances have IPv6 inside networks and the outside network is IPv4 (IPv6 addresses on the inside interface and IPv4 addresses on the outside interfaces)."
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/site2sit.html
Here is a sample schema of the lab :
Note that I can ping both peers in IPv6 (ping fc00::2 from fc00::3 and vice-versa).
For the L2L configuration :
When I set the IPv4 address of the peer, everything works fine (both host can ping each others)
When i set the IPv6 address of the peer, the tunnel is up(there is traffic according to the VPN stats) but there is no "trace" of the traffic on the other side.
For example :
When I ping 10.1.2.2 from 10.1.1.2, I can see traffic in the tunnel (VPN stats in asdm), but the host 10.1.2.2 doesn't receive any echo request. ASA (with 10.1.1.1) doesn't see any traffic too.
Any help would be appreciated,
Thanks.
cturacci Thu, 04/12/2012 - 08:54
Hi Armand Arma,
Do you simulating the
I'm running a lab with GNS3 which is composed of 2 ASA's (8.4.2)" in one GNS Instance..
Sorry for that question, if yes.. !
Could you describe how you done that "2 ASA´s" are running in "one GNS3 window" at same time !
cturacci
Phillip Remaker Thu, 04/12/2012 - 15:53
  • Cisco Employee,
It's hard to say without seeing the device configurations.
cturacci Tue, 04/17/2012 - 07:59
hi Philipp,
sorry not noticed that your notification placed for the (Armand Arma).. forget my infos.. to you ;-)
CT
Kooopobol Thu, 05/24/2012 - 13:07
Here are the startup-configs of these two ASA.
cturacci : I don't understand.. Do you want to know how to run 2 ASA's at the same time with GNS 3?
: Saved
: Written by admin at 12:24:50.379 UTC Fri Apr 6 2012
ASA Version 8.4(2)
hostname ASA800A
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0
description outside interface
nameif outside
security-level 0
ip address 192.168.1.3 255.255.255.0
ipv6 address fc00::3/64
ipv6 enable
ipv6 nd suppress-ra
interface GigabitEthernet1
description inside network
nameif inside
security-level 100
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet5
nameif management
security-level 0
ip address 10.10.10.3 255.255.255.0
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_access_in extended permit ip any any inactive
access-list outside_access_in extended permit ip 10.1.2.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list outside_cryptomap extended permit ip 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0
access-list outside_cryptomap_1 extended permit ip 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ipv6 access-list outside_access_ipv6_in permit ip any any
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
access-group outside_access_in in interface outside
access-group outside_access_ipv6_in in interface outside
route outside 10.1.2.0 255.255.255.0 192.168.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.10.10.2 255.255.255.255 management
http redirect management 80
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto map outside_map0 1 match address outside_cryptomap_1
crypto map outside_map0 1 set pfs
crypto map outside_map0 1 set peer fc00::2
crypto map outside_map0 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 interface outside
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
group-policy GroupPolicy_fc00::2 internal
group-policy GroupPolicy_fc00::2 attributes
username admin password f3UhLvUj1QsXsuK7 encrypted privilege 15
tunnel-group fc00::2 type ipsec-l2l
tunnel-group fc00::2 general-attributes
default-group-policy GroupPolicy_fc00::2
tunnel-group fc00::2 ipsec-attributes
ikev1 pre-shared-key *****
: Saved
: Written by admin at 13:06:09.109 UTC Fri Apr 6 2012
ASA Version 8.4(2)
hostname ASA235A
names
nameif outside
security-level 0
ip address 192.168.1.2 255.255.255.0
ipv6 address fc00::2/64
ipv6 enable
ipv6 nd suppress-ra
nameif inside
security-level 100
ip address 10.1.2.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 0
ip address 10.10.10.1 255.255.255.0
ftp mode passive
access-list outside_cryptomap extended permit ip 10.1.2.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list outside_access_in extended permit ip 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
arp timeout 14400
route outside 10.1.1.0 255.255.255.0 192.168.1.3 1
http server enable
crypto map outside_map0 1 set peer fc00::3
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
group-policy GroupPolicy_fc00::3 internal
group-policy GroupPolicy_fc00::3 attributes
tunnel-group fc00::3 type ipsec-l2l
tunnel-group fc00::3 general-attributes
default-group-policy GroupPolicy_fc00::3
tunnel-group fc00::3 ipsec-attributes
Related Content
