NAT/Opening a Port on ASA 5505
pgmccullough
Hi everyone--I'm very green, but my friend was against a wall trying to update her office's system, and it seems like every Cisco person in the region has gone on vacation.
For some sort of new system her office is getting, she was told that she needed to enable NAT with external IP xxx.xxx.xxx.14 (The ASA's IP is xxx.xxx.xxx.11) and internal IP xxx.xxx.xxx.58 and that port 8222 needs to be open.  I know this is sort of vague, but it's what she was given, and I know the 8222 port is very specific in function, so hoping that makes obvious to experts what the point of this is?
At any rate, the best I could come up with was to run:
static (inside,outside) xxx.xxx.xxx.58 xxx.xxx.xxx.14 netmask 255.255.255.255
access-list inbound extended permit tcp any host xxx.xxx.xxx.11 eq www
access-list inbound extended permit tcp any host xxx.xxx.xxx.11 eq https
access-list inbound extended permit tcp any host xxx.xxx.xxx.11 eq 8222
access-list inbound extended permit udp any host xxx.xxx.xxx.11 eq 8222
access-group inbound in interface outside
But after I inserted this, she did what she was supposed to be able to do (went home and tried to run some sort of remote installation file) and it didn't work...  can anyone shed any light on this?
Thanks a million in advance.
8 Replies 8
llamaw0rksE
Okay going to make some assumptions here.
An external user or external corporate IP (many users) of IP xx.xx.xx.14 needs access via port 8222, to an internal private IP behind the ASA of xx.xx.xx.58.   Furthemore the WANIP of the ASA is xx.xx.xx.11
Also will assume the router already has dynamic pat setup, routing for traffic to the next hop (IP address of gateway of ISP) and ACL rules identified with outside interface.
For version firmware 8.43
object network extuser
host xx.xx.xx.xx.14
object service specialfunction
service tcp destination eq 8222
object network PC-serving-IP
host xx.xx.xx.58
object network Nat4specfunction
host xx.xx.xx.xx.14
access-list outside_access_in extended permit object specialfunction object extuser object PC-serving-IP
nat(inside,outside) static interface service tcp 8222 8222
If the outside interface is not .11, and its simply another of a group of public IP associated to the ASA then make an object definition for later use.
object network anotherextIP
host xx.xx.xx.11
nat(inside,outside) static anotherextIP service tcp 8222 8222
Thanks so so much for taking time to give me this.  Really do appreciate it.
I could be wrong, but I believe all of your assumptions are accurate.  I'm going in to the friend's office tomorrow to try and get it running.  Hopefully I can come back and mark "correct answer" tomorrow afternoon!
In the meantime, just in case, I guess I'll attach the configuration.  Maybe a quick glance can confirm your assumptions for you regarding router already having dynamic pat setup, routing for traffic to the next hop (IP address of gateway of ISP) and ACL rules identified with outside interface.
Thanks again.  I never would have gotten this on my own, obviously.
ASA Version 7.2(3)
hostname [top secret!]
domain-name [top secret!]
enable password [top secret!] encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address [top secret!].140 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address [top secret!].11 255.255.255.248
interface Vlan3
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd [top secret!] encrypted
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip [top secret!] 255.255.255.0 10.0.
8.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 10.0.50.0 255.255.255.24
8
access-list inside_nat0_outbound extended permit ip 10.0.1.0 255.255.255.0 10.0.
6.0 255.255.255.0 – Not in your configuration
access-list outside_1_cryptomap extended permit ip 10.0.1.0 255.255.255.0 10.0.8
.0 255.255.255.0
access-list tr-remote_splitTunnelAcl standard permit any
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit esp any any
access-list outside_access_in extended permit tcp [top secret!] 255.255.255.0 any eq
smtp
access-list outside_2_cryptomap extended permit ip 10.0.1.0 255.255.255.0 10.0.6
pager lines 24
logging enable
logging monitor debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool remote-vpn 10.0.50.0-10.0.50.7 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface smtp 10.0.1.201 smtp netmask 255.255.255.2
55
access-group outside_access_in in interface outside – Not in your configuration
route outside 0.0.0.0 0.0.0.0 [top secret!].9 1 – was [top secret!].194 in you config
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 10.0.6.0 255.255.255.0 inside – Not in your configuration
http 10.0.8.0 255.255.255.0 inside – Outside in your configuration
http 10.0.1.0 255.255.255.0 inside
http 10.0.50.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac – Not in your configuration
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA – Not in your configuration
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer [top secret!].194
crypto map outside_map 1 set transform-set ESP-DES-MD5
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set pfs
crypto map outside_map 2 set peer [top secret!].162
crypto map outside_map 2 set transform-set ESP-3DES-SHA – Not in your configuration
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
telnet 10.0.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout none
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
smartcard-removal-disconnect enable
client-firewall none
client-access-rule none
webvpn
  functions url-entry
  html-content-filter none
  homepage none
  keep-alive-ignore 4
  http-comp gzip
  filter none
  url-list none
  customization value DfltCustomization
  port-forward none
  port-forward-name value Application Access
  sso-server none
  deny-message value Login was successful, but because certain criteria have not
been met or due to some specific group policy, you do not have permission to us
e any of the VPN features. Contact your IT administrator for more information
  svc none
  svc keep-installer installed
  svc keepalive none
  svc rekey time none
  svc rekey method none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate – Not in your configuration
group-policy tr-remote internal
group-policy tr-remote attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value tr-remote_splitTunnelAcl
group-policy staff-remote internal
group-policy staff-remote attributes
dns-server value 10.0.1.200
username remote password [top secret!] encrypted privilege 0
username remote attributes
vpn-group-policy [top secret!]
username [top secret!] password [top secret!] encrypted privilege 0
username [top secret!] attributes
vpn-group-policy tr-remote
tunnel-group [top secret!].194 type ipsec-l2l
tunnel-group [top secret!].194 ipsec-attributes
pre-shared-key *
tunnel-group tr-remote type ipsec-ra
tunnel-group tr-remote general-attributes
address-pool remote-vpn
default-group-policy tr-remote
tunnel-group tr-remote ipsec-attributes
pre-shared-key *
tunnel-group [top secret!].162 type ipsec-l2l
tunnel-group [top secret!].162 ipsec-attributes
pre-shared-key *
tunnel-group staff-remote type ipsec-ra
tunnel-group staff-remote general-attributes
default-group-policy [top secret!]
tunnel-group [top secret!] ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:[top secret!]
andrew.prince
Level 10
Level 10
access-list inbound extended permit tcp any host 24.105.143.11 eq 8222
access-list inbound extended permit udp any host 24.105.143.11 eq 8222
The NAT and the ACL last octet do not match!
Yeah, all I knew was that the asa ip was xxxxxxx.11 and that the actual external ip was xxxxxxxxxxx.14, so I just thought they needed to be pointed at each other and that was the way to do it.
Thanks so much for replying.
Message was edited by: Patrick McCullough
Thanks again for spotting the flaw--do you have any idea whether the code ought to work if altered to make the nat and acl match?
Yes - it would have worked.
llamaw0rksE
My input is only valid for 8.43, it wont help you for the older version. My apologies.
Oops!  Oh well--no need to apologize certainly!  Not only have you helped clarify my question for other experts, but if worse comes to worse, I could probably Google the older equivalent of each command in your code?
