Basic VPN Question
Apr 6th, 2012
HI
I was wondering if someone could explain a VPN concept to me.
I have been taught to create VPNS by creating a VRF on the PE router which exchanges information with BGP.
IF my CE router is using a further 2 interfaces and each wishes to independantly access different VPNs via the PE, but still want to be able to access each other. how is this acheived?
I'm working with an MPLS, OSPF, IP based network.
Basic toptology attached
David Imrie Sat, 04/07/2012 - 08:30
Yes? As i understand it the RD is a unique identifier for the vrf instance.
the example I have is
ip vrf VPN1
rd 999:1
route-target both 64999:1
router bgp 64999
no bgp default ipv4-unicast
neighbor 10.10.10.11 remote-as 64999
neighbor 10.10.10.11 update source fa0/0
address-family vpnv4
neighbor 10.10.10.11 activate
it then goes on to set up rip and redistribute the BGP entries via rip.
My question is that if i only want some subnets/interfaces on the router attached to this PE router to access the VPN how do i do that? do i use access lists of some kind? as both interfaces on the client router will be able to route to the vpn with this setup, which I dont want.
Hi David
The principle of VPNs (although I would recommend using the term L3VPN to avoid confusion with IPSec oriented VPNS) is the separation of routing information from different customers. This is done with VPN Routing Forwarding (VRF) instances using route distinguished (RD); to make a prefix unique and route-targets (extended BGP communities) to identify which of those prefixes will be installed into the customer specific Forwarding Information Base (FIB) aka routing table.
In its simplistic form, a different customer will have a different route-target community and separate route-distingishers, but it's possible to create very complicated hub-spoke, partial mesh L3VPNs with VRF route-maps.
Derek
David Imrie Sat, 04/07/2012 - 12:07
Thanks for the help guys. I think I am failing somewhere when it comes to basic undestanding of seting up VRF or BGP though as I cant get a simple point to point link to share routing info,
Can anyone tell me what I am doing wong looking at my router configs?
ROUTER PE1:
version 12.4
hostname PE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip vrf 2_ADM_PAY
rd 999:1
route-target export 64999:1
route-target import 64999:1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip vrf forwarding 2_ADM_PAY
ip address 10.1.1.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
mpls label protocol ldp
mpls ip
router ospf 1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 192.168.1.0 0.0.0.255 area 0
router rip
version 2
network 10.0.0.0
no auto-summary
address-family ipv4 vrf 2_ADM_PAY
redistribute bgp 64999 metric 1
no auto-summary
exit-address-family
router bgp 64999
bgp log-neighbor-changes
neighbor 4.4.4.4 remote-as 64999
neighbor 4.4.4.4 update-source Loopback0
neighbor 4.4.4.4 activate
neighbor 4.4.4.4 send-community extended
exit-address-family
redistribute rip metric 1
no synchronization
exit-address-family
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
Router PE2:
version 12.4
hostname PE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip vrf 2_ADM_PAY
rd 999:1
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip address 10.1.1.6 255.255.255.252
duplex auto
speed auto
ip address 192.168.1.9 255.255.255.252
duplex auto
speed auto
mpls ip
router ospf 1
network 4.4.4.4 0.0.0.0 area 0
router rip
version 2
network 10.0.0.0
no auto-summary
exit-address-family
router bgp 64999
neighbor 1.1.1.1 remote-as 64999
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 send-community extended
exit-address-family
no synchronization
exit-address-family
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
David - basically your config is wrong in a few places.  When I was learning to configure MPBGP/VRF/MPLS for the first time, I took a stepped approach and it worked for me, I did the below steps......
1) Get basic OSPF working with both sides seeing the Loopbacks.
2) Get LDP working from end to end - confirm with label debugs.
3) Get basic BGP working.
4) Configure the VRF's to the local interfaces only - confirm the VRF routing tables.
5) Configure the VRF routing protocol.
6) Configure the MPBGP.
Then see where you are.
Hope this is helpfull.
I'm only able to ready he PE1 configuration correctly, but based on that, move the network statement under router rip to the VRF address family, this will enable RIP on the VRF specific interface. Another recommendation, but not critical is to have redistribute connected in BGP address-family VRF as well.
David Imrie Sat, 04/07/2012 - 14:21
Thanks.
I found that it worked once I added 10.0.0.0 under the address family.
I'm still completely clueless how to have multiplt vpns terminating at different points on the same site though.
To have another L3VPN/customer on the same PE all you need is another interface where that customer connects and you build another specific VRF for them.
See below, the important items:
1. New VRF Name, RD and RT values
2. New f0/3 interface
3. Same routing parameters but all under a new address-family
4. The interface IP address is identical to the previous VRF, this is deliberate to show that different VRFs/customers can have duplicate addressing.
ip vrf customer3
rd 999:3
route-target export 64999:3
route-target import 64999:3
interface FastEthernet0/3
ip vrf forwarding customer3
router rip
address-family ipv4 vrf customer3
network 10.0.0.0
no auto-summary
exit-address-family
router bgp 64999
no synchronization
exit-address-family
Hope this helps
David Imrie Sun, 04/15/2012 - 10:44
Is multiple vrfs not the technique known as VRF lite? I have been asked to complete this exercise without using "Mpls lite" though I'm sure my tutor meant VRF-lite
