Warning message
Subinterface doesn't respond to pings - NP Identity ifc
Apr 6th, 2012
I'm trying to set up an 802.1 q trunk between my layer 3 switch and ASA5520.  I understand I need to create a subinterface to accomplish this and have done so.  However, the subinterface does not respond to pings, and when I attempt to run the packet tracer on the firewall itself, I get a message saying Flow is denied by configured rule.  But the strange thing is it shows the output interface as "np identity ifc":
(The VLAN in question is VLAN2 192.168.2.3 is the VLAN2 address on the switch).  The ASA config is as follows:
ASA Version 8.2(5) <context>
hostname context2
names
interface GigabitEthernet0/0.2
nameif Inside0/0.2
security-level 20
ip address 192.168.2.1 255.255.255.0 standby 192.168.2.2
interface Outside
nameif Outside
security-level 40
ip address 157.142.246.132 255.255.255.0 standby x.x.246.134
interface Management
nameif Management
security-level 100
ip address 192.168.4.2 255.255.255.0 standby 192.168.4.4
management-only
no nameif
no security-level
no ip address
pager lines 24
mtu Outside 1500
mtu Management 1500
mtu Inside0/0.2 1500
no monitor-interface Outside
no monitor-interface Management
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route Outside 0.0.0.0 0.0.0.0 x.x.246.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
http server enable
http 192.168.0.0 255.255.0.0 Management
http 192.168.0.0 255.255.0.0 Inside0/0.2
no snmp-server location
no snmp-server contact
telnet 192.168.0.0 255.255.0.0 Management
telnet 192.168.0.0 255.255.0.0 Inside0/0.2
telnet timeout 5
ssh timeout 5
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
: end
jhampt20_ford Sat, 04/07/2012 - 06:09
The sub-interface needs a vlan id, something like:
vlan 2
nameif Inside0/0.2
security-level 20
Also on the switch dont forget to create vlan 2, than double check that it is allowed to cross the trunk.
kerry-davis@ino... Sat, 04/07/2012 - 08:32
Thanks for the reply.
A bit more info - the ASA is part of an active/active pair, and from what I understand, the VLAN can only be set at the system level.  I have done this for int gigabitethernet0/0.2 in the system config (VLAN2), but for some reason when I show the config at the context level it does not show the VLAN.
Also, I have confirmed the switchport is set for 802.1q trunking and VLAN 2 is allowed.
Is there something else I need to do to make sure the VLAN assignment is applied at the context level on the ASA?  Also, would this prevent the packet tracer from pinging the interface from the same subnet?
A little stumped here.
