Catalyst 6509E with a redundant supervisors, all ten uplinks active
Apr 6th, 2012
On the Catalyst VSSE 720 supervisor data sheet I found that this supervisor: "Allows two 10 Gigabit Ethernet and two Gigabit Ethernet uplinks to be active simultaneously; with redundant supervisors, allows all ten uplinks to be active"
Can anyone help me to configure this feature?
Thanks a lot.
Roberto
Reza Sharifi Sat, 04/07/2012 - 09:45
  • Cisco Designated VIP,
    2017 LAN
Few questions
Are you running VSS?
With one sup in each switch or two?
Are you using port channel?
rosarra Sat, 04/07/2012 - 11:39
I would like to configure the redundancy also using port channel features.
I've a Catalyst 6509E with a redundant 720 supervisor, and two Catalyst 4506E with a single supervisor card.
It's possible to connect both Cat 4509 10GE (total 4 interface) to Cat6509 10GE using redundant supervisor 10GE interface?
Reza Sharifi Sat, 04/07/2012 - 13:42
    2017 LAN
No, since the 2 4509 chassis can not be combined (VSS) (at this time), it is not possible.  You can certainly build a Portchannel using all 4 10GE on the 6500 and connect them to only one 4509, but not to both 4509s.
Related Content
