Vulnerability assesment Tool
Answered Question
Apr 7th, 2012
Hello All
Seeking for suggestion on vulnerability assesment Tool for Router and Switches. Appreciate kind input
cheers
Saquib
Correct Answer by sean_evershed about 4 years 11 months ago
IOS has a built in auto secure feature. See below
http://blog.ipexpert.com/2011/04/25/ciscos-autosecure/
See also this list of tools. One of my favorites is Nipper.
http://packetlife.net/armory/category/vulnerability-scanning/
You can also copy your config into the Output Interpreter for an analysis
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
Don't forget to rate posts that are helpful.
Cheers
Sean
Overall Rating: 5 (1 ratings)
Correct Answer
sean_evershed Sat, 04/07/2012 - 02:02
  • Gold, 750 points or more
Cheers
Sean
Audrius Jonavicius Tue, 04/10/2012 - 11:58
I would recommend to look at Nessus or NeXpose Vulnerability assesment/managment tools.
Audrius
