How to use telnet to enable SNMP in a router ?
Jeff Van Houten Sat, 04/07/2012 - 10:01
For the Cisco, after you login, snmp is enabled with the snmp-server command, as in snmp-server community (community string) RO
DALHI_Ahmed Sat, 04/07/2012 - 10:16
Hi Jeff,
Do you mean login using telnet ?
Can you explain more please ?
Jeff Van Houten Sat, 04/07/2012 - 10:18
Yes if telnet is enabled on the router.
From the telnet client on your pc, type "telnet (ip address of router)", then proceed through the user name and password prompts.
DALHI_Ahmed Sat, 04/07/2012 - 10:28
telnet @router
login: root
Password: ********
[root @ home]$
What I should do next Jeff ?
Thank you.
