Warning message
Can't open port on ASA!
Apr 7th, 2012
If anyone thinks they can help, please do, I'm desperately trying to help a company with a short term deadline.  Just doing it to help out a friend in a rural area where every CISCO tech contact they had seems to be unavailable (For the last and next week) all at once.  I'm tearing my hair out!  Here's the current ASA configuration:
ASA Version 7.2(3)
hostname [top secret!]
domain-name [top secret!]
enable password [top secret!] encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address [top secret!].140 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address [top secret!].11 255.255.255.248
interface Vlan3
shutdown
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd [top secret!] encrypted
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip [top secret!] 255.255.255.0 10.0.
8.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip any 10.0.50.0 255.255.255.24
8
access-list inside_nat0_outbound extended permit ip 10.0.1.0 255.255.255.0 10.0.
6.0 255.255.255.0 – Not in your configuration
access-list outside_1_cryptomap extended permit ip 10.0.1.0 255.255.255.0 10.0.8
.0 255.255.255.0
access-list tr-remote_splitTunnelAcl standard permit any
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit esp any any
access-list outside_access_in extended permit tcp [top secret!] 255.255.255.0 any eq
smtp
access-list outside_2_cryptomap extended permit ip 10.0.1.0 255.255.255.0 10.0.6
pager lines 24
logging enable
logging monitor debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool remote-vpn 10.0.50.0-10.0.50.7 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface smtp 10.0.1.201 smtp netmask 255.255.255.2
55
access-group outside_access_in in interface outside – Not in your configuration
route outside 0.0.0.0 0.0.0.0 [top secret!].9 1 – was [top secret!].194 in you config
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 10.0.6.0 255.255.255.0 inside – Not in your configuration
http 10.0.8.0 255.255.255.0 inside – Outside in your configuration
http 10.0.1.0 255.255.255.0 inside
http 10.0.50.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac – Not in your configuration
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA – Not in your configuration
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer [top secret!].194
crypto map outside_map 1 set transform-set ESP-DES-MD5
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set pfs
crypto map outside_map 2 set peer [top secret!].162
crypto map outside_map 2 set transform-set ESP-3DES-SHA – Not in your configuration
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
telnet 10.0.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout none
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
smartcard-removal-disconnect enable
client-firewall none
client-access-rule none
webvpn
  functions url-entry
  html-content-filter none
  homepage none
  keep-alive-ignore 4
  http-comp gzip
  filter none
  url-list none
  customization value DfltCustomization
  port-forward none
  port-forward-name value Application Access
  sso-server none
  deny-message value Login was successful, but because certain criteria have not
been met or due to some specific group policy, you do not have permission to us
e any of the VPN features. Contact your IT administrator for more information
  svc none
  svc keep-installer installed
  svc keepalive none
  svc rekey time none
  svc rekey method none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate – Not in your configuration
group-policy tr-remote internal
group-policy tr-remote attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value tr-remote_splitTunnelAcl
group-policy staff-remote internal
group-policy staff-remote attributes
dns-server value 10.0.1.200
username remote password [top secret!] encrypted privilege 0
username remote attributes
vpn-group-policy [top secret!]
username [top secret!] password [top secret!] encrypted privilege 0
username [top secret!] attributes
vpn-group-policy tr-remote
tunnel-group [top secret!].194 type ipsec-l2l
tunnel-group [top secret!].194 ipsec-attributes
pre-shared-key *
tunnel-group tr-remote type ipsec-ra
tunnel-group tr-remote general-attributes
address-pool remote-vpn
default-group-policy tr-remote
tunnel-group tr-remote ipsec-attributes
pre-shared-key *
tunnel-group [top secret!].162 type ipsec-l2l
tunnel-group [top secret!].162 ipsec-attributes
pre-shared-key *
tunnel-group staff-remote type ipsec-ra
tunnel-group staff-remote general-attributes
default-group-policy [top secret!]
tunnel-group [top secret!] ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:[top secret!]
an epic thin client is being set up and the company was simply told to (on their Cisco ASA) enable NAT, with external ip xxx.xxx.xxx.14, internal ip 10.0.xx.xx, and open port 8222.
I went in and added this:
static (inside,outside) xxx.xxx.xxx.58 xxx.xxx.xxx.14 netmask 255.255.255.255
access-list inbound extended permit tcp any host xxx.xxx.xxx.14 eq www
access-list inbound extended permit tcp any host xxx.xxx.xxx.14 eq https
access-list inbound extended permit tcp any host xxx.xxx.xxx.14 eq 8222
access-list inbound extended permit udp any host xxx.xxx.xxx.14 eq 8222
access-group inbound in interface outside
But when we try and run the thin client install, we get an error saying invalid ip/port xxx.xxx.xxx.14/8222.
Please help if you can.  I'd be so appreciative.  Have already been so thankful for earlier responses.
pgmccullough Sat, 04/07/2012 - 08:51
Thanks so much for the quick reply!
Okay, I switched it to
static (inside,outside) xxx.xxx.xxx.14 xxx.xxx.xxx.58 netmask 255.255.255.255
but it didn't appear to make a difference.
Do I need to also change all of the access-list lines to define the xxxxxxx.58 (internal) ip instead of the xxxxxxxxxxxx.14 (external)?
pgmccullough Sat, 04/07/2012 - 10:41
Okay--so the ASA's ip is xxxxxxxxx.11.  The external ip that needs to be set up for this is xxxxxxxxxx.14 and point to internal ip xxx.xxx.xxx.58 with port 8222 open.
So originally I had:
access-list inbound extended permit tcp any host xxx.xxx.xxx.11 eq www
access-list inbound extended permit tcp any host xxx.xxx.xxx.11 eq https
access-list inbound extended permit tcp any host xxx.xxx.xxx.11 eq 8222
access-list inbound extended permit udp any host xxx.xxx.xxx.11 eq 8222
but a commenter on another discussion said that the 14 and 11 needed to match.  So I changed to
Above poster pointed out that static statement needed to be swapped, so it became:
I am certain that the swapping statics was correct, but it didn't make a difference.  I went back and tried to run the epic thin client set up, and still got an invalid ip/port error.
So I went back to having the original instance of pointing from the public IP the thin client will connect to, to the ASA ip.  And I went nuclear with permissions:
access-list inbound extended permit tcp any host xxx.xxx.xxx.58 eq www
access-list inbound extended permit tcp any host xxx.xxx.xxx.58 eq https
access-list inbound extended permit tcp any host xxx.xxx.xxx.58 eq 8222
access-list inbound extended permit udp any host xxx.xxx.xxx.58 eq 8222
And now the thin client install gives another error, saying it can't install to specified host or something.  Which feels like progress!  Though I'm sure the access-list inbound on everything is a bad security idea.  I just needed to play around to see what was going on.
Any thoughts?
Amit Rai Sat, 04/07/2012 - 22:52
did you try to run the packet tracer to find out what is causing the issue.
also try to capture the traffic on the ingress and egress interface to see if the issue is at the ASA or somewhere else.
refer to the below link for the packet capture on ASA
https://supportforums.cisco.com/docs/DOC-17345#comment-8416
Send me the output of the below command.
packet-tracer input outside tcp 1.1.1.1 1234 xxx.xxx.xxx.58 8222 det
Roman Rodichev Sun, 04/08/2012 - 00:18
  • Gold, 750 points or more
This is absolutely correct:
Static goes as : inside outside externalIP internalIP
Inbound outside ACL must reference externalIP
starting with ASA code 8.3 (you are running something before 8.3), there are no more static commands, and ACL would have to reference internalIP
Can you telnet to xxx.xxx.xxx.14 ports 80, 443 and 8222 from outside. Just do "telnet xxx.xxx.xxx.14 80", if it connects, then you are good, if not, then something's wrong. Verify that you can telnet xxx.xxx.xxx.58 80 from inside. And verify that xxx.xxx.xxx.14 is definitely routed to the ASA's outside interface.
pgmccullough Mon, 04/09/2012 - 11:54
Thanks so much.  At this point, it looks like things OUGHT to be working.  I can successfully telnet xx.xx.xx.14 8222, which seems like it bodes well.  I can't tell you how deeply I appreciate everyone's responses.  I will come back and rate appropriately once we can confirm success in the next day or two.
pgmccullough Mon, 04/09/2012 - 09:15
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0x3582098, priority=1, domain=permit, deny=false
        hits=1722090, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.0.1.0        255.255.255.0   inside
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0x35fa678, priority=11, domain=permit, deny=true
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Jouni Forss Mon, 04/09/2012 - 11:28
Can you also post the whole "packet-tracer" command that you used for the above output?
To my understanding if you just want to give an inside IP address its own public IP address it should be done the way it was already mentioned.
static (inside,outside) netmask 255.255.255.255
access-list permit tcp any host eq 8222
If you test the configuration with "packet-tracer" command the format should be this
packet-tracer input outside tcp 1.2.3.4 1025 8222
Command parameters in order from left to right
  • packet-tracer = the command itself
  • input = the input parameter (no other available) used before giving the actual interface name on ASA
  • outside = the interface name on the ASA
  • tcp = protocol used
  • 1.2.3.4 = random source address chosen
  • 1025 = random source port chosen
  • = the IP address you have chosen for the static command
  • 8222 = the port you were asked to open (or any other port you need to test)
- Jouni
Related Content
